Don't know where to post this but I figured more folks would have FF on the diesel forum.
From reading many threads on MUD, it seems that one downside of LC FF rear axles is that the bearings require routine grease packing as they are separated from the differential lube with the inner axle seal. On all of the Dana FF's, there is no seal so the axle bearings are lubed by the lube in the differential. Seems to work very well.
Why not leave out the inner axle seal and eliminate the routine repacks of the bearings? Maybe the lube level in the dif would have to be raised but it seems like it would work.
Has anyone tried this?
