EDIT: I ran into some problems with my initial approach. See Post #36 for details and solution.
As part of my attempt to swap an Isuzu 4HE1 diesel into my FJ62, I looked into ways to make my stock tach work with the diesel. The solution I used is very simple and can be applied to any diesel or any other engine for that matter.
The stock FJ62 tach is calibrated to read the correct RPM based on three ignition pulses per engine revolution. To provide these pulses, I used an ABS wheel sensor from an FJZ80 rear end that I happened to have available. Almost any ABS sensor will work as long as it incorporates a magnet and has only two wires. To provide three pulses per engine revolution, I cut three notches in the circumference of the flywheel. I mounted the sensor through an existing hole in the flywheel housing using a simple aluminum spacer. The first photo shows the modified flywheel, the ABS sensor and the mounting spacer. The second photo shows them in place on the engine. I ended up with a gap of 0.056” between the sensor and the edge of the flywheel.
I chose to mount the sensor adjacent to the flywheel because, in my case, it was convenient. You could also use the harmonic balancer as a signal source. I chose to cut the three semicircular notches in the circumference of the flywheel, again, because it was convenient. I used a ¾” end mill. You could also drill holes perpendicular to the circumference of the flywheel or harmonic balancer. All you are trying to do is to disrupt the magnetic flux as the notch/hole passes by the sensor. Probably more important in the selection of your modification is not to destroy the balance of the flywheel/harmonic balancer or damage their integrity.
