- Joined
- Nov 22, 2010
- Threads
- 44
- Messages
- 2,151
- Location
- Wilmington, NC
- Website
- www.kindredspiritscsg.com
This is a great thread, I Just installed a FZJ80 ABS sensor on the harmonic balancer of 6BT. Hopefully it works. I will be sure to post up when I test fire the motor next week.
Quick question about hooking it up to the tach, Can the wires that originally went to the coil be reused?
You certainly can use the wires that originally went to the coil.
So is my post above how everyone else has done it and it worked
Thanks
When I got my engine started yesterday, the tach sensor bounced around a lot. It seemed like sometimes it would sync bit generally was all over the place. Have you noticed anything like this before? The cutouts on the flywheel are at least 2.5" long and are maybe 0.5" deep. Could the wires be swapped or do you think it is filter (capacitors) at the gauge doing too good a job?
Also, on the caps, are they in parallel? If so, you can remove one and half the total capacitance versus removing both and putting on two capacitors that are half the size.
Yes I meant the tach needle.
The gap is super close and I don't think that is the issue.
The second edge causing a false read sounds like it could be it. I will try reaching in there to put a diode across it. Getting to it is pretty tough, but I can remove the starter sort of easily. I will try, possibly this weekend, and report back.
.... Question though...could I essentially use the hall effect sensor in reverse? For what I am thinking it'd be easier to have tabs three tabs that swing by the sensor rather than three voids. Not sure if that makes sense. I suppose another way of saying it is rather than sensor mainly seeing something close and an occasional void, I'd like to to mainly see nothing and three times per rev see something 'close'. It seems like if the tach is just looking for the change in sensor state 3x per rev either way would work...but maybe not...
Andy
