Hard Day's Work; Al's Liner
Tulsa, OK
www.cardomain.com
This was not a difficult project but it takes quite a while; a lot of attention to detail and prep work. I started out by dropping the truck off at a friends house to weld up all the holes, (I don't weld thin stuff). After getting the truck back, I skimmed the weld areas with filler and sanded everything down.
Next day, (the long one). I started out by drying off the truck, as it had been raining. Next I taped off the lines I wanted with some "wire tape". The tape has a thin cutting element (wire) in one edge of it. It's neat stuff but kind of a PITA to work with. The areas where the standard blue tape was used peeled up just fine. After the wire tape I had to add a line of blue painters tape, as the wire tape is only 1/4" wide.
After that I added plastic sheeting to the rest of the truck and had to tape that down too. The masking session is by far the most labor intensive portion; sans the holes I guess. Next I sprayed on the "adhesive promoter", which has an incredibly strong smell to it. I let that sit until tacky and then brewed up the first batch, 1/2 gallon. I chose to spray the liner on with the Harbor Freight texture gun (same as Al's gun but way cheaper). I also had my own tint brewed and used 5 ounces on the first 1/2 gallon and 6 ounces on the second 1/2; no difference to speak of. What ever color you decide, choose a couple shades darker. I had the original batch tinted darker over and over and it's still a little lighter than I was wanting, no complaints though.
Quantity:
I was kinda worried initially because I left the holes/ filler white instead of painting them black, which made it harder to cover up. It went on a little thick the first time around and I decided I wanted a finer texture. After gathering some useful tips from Mud, I decided to turn the pressure up a bit 125psi, and lightly squeeze the trigger. This technique gave the texture I was looking for.
The bumpers/ sliders have been re painted (black) and will be going back on in a couple days.
P.S. Big thanks to Delancy for the use of his facility and compressor.
I'm working up to this myself! Looks great!
Looks nice. If my rig ever gets scratched up I'm going old school Toyota tan colored liner on the whole thing. Wish the 80's in the US would have come in that color from the factory. To me that is the best color on a Toyota truck. Was your bumper removed for doing this or do you always have it off? Tempted to pull mine to start working on a tube bumper.
I love the grey on black - looks like a really good combination for your truck.
I need to figure out the right complimentary color to champagne :0
Edit - hey, my 1,000th post.
After I sprayed mine, it continued to get darker over the next 72hrs. Dana from Al's said that it had something to do with the white colored fluid that you mix into your batch. Apparently it dries clear after its cured.
Should be pretty darn close to the base that you added to tint it after its cured
Sent from my iPad using IH8MUD
That would be cool too. Did you use flattner? It's white also.
I actually didn't use a flattener on mine. I did, however, get a chance to park next to the vehicle that I borrowed the paint code from and it's a dead match.
When I first sprayed it, I didn't think it was going to be close at all... But, it did cure out just like the guy said.
Be sure and post up some more pics in a week, and I bet the comparison will be obvious!
Nicely done. Lookin good!
KR,
Great job! Your patience definitely paid off.
Looks good. You definitely prepped smarter than I did. I should have used the plastic drop cloth but instead I used paper masking and it took forever. I expected to have lots of over spray which I didn't.
Aikirilo, you gonna share your total outlay on welding the holes up?
My eyes burn from welding flash( back) just thinking of mine almost a year later.
Your deal had to be the best money ever invested on an LX, period.
For starters, its akarilo :flipoff2:
My "buddy" said he would weld up a fellow LX'ers holes for $350 if anybody is interested. Gotta be cheaper than one could find elsewhere.
By "buddy" said he would weld up a fellow LX'ers holes for $350 if anybody is interested. Gotta be cheaper than one could find elsewhere.
Where's your buddy located?
