Here's the FSM diagnostic proceedure courtesy of Raventai.
2. Using diagnosis check wire:
CHECK DTC
(a) Output the DTC.
(1) Turn the ignition switch to ACC or ON position and
wait approx. 20 seconds.
(2) Using SST, connect terminals Tc and E1 of the
DLC1.
SST 09843–18020
NOTICE:
Never make a mistake with the terminal connection position
as this will cause a malfunction.
(b) Read the DTC.
Read the 2–digit DTC as indicated by the number of times
the SRS warning light blinks. As an example, the blinking
patterns, normal, 11 and 31 are as shown on the illustration.
Normal code indication
The light will blink 2 times per second.
– DIAGNOSTICS SUPPLEMENTAL RESTRAINT SYSTEM
Malfunction code indication
The first blinking output indicates the first digit
of a 2–digit DTC. After a 1.5 second pause,
the second blinking output will indicate the
second digit.
If there are 2 or more codes, there will be a 2.5 second pause
between each codes. After al the codes have been output,
there will be a 4.0 second pause and they will all be repeated.
HINT:
In the event of a number of trouble codes, indication will
start from the smallest numbered code.
If it does not output a DTC or outputs a DTC without terminal
connection, proceed to the Tc terminal circuit inspection
on page DI–267.
1996 LEXUS LX450 (RM482U)
Does anyone have the FSM reset proceedure? I've been working on the LX and disconnected the battery for too long or one too many times. There's nothing wrong with my airbag system. There's tons of threads where people mention they used a paperclip and a couple of wires, but no mention of what they did with them. I really don't want to buy another FSM and I'm not downloading it on a dial-up connection.
Thanks!
CHECK DTC
(a) Output the DTC.
DLC1.
SST 09843–18020
NOTICE:
(b) Read the DTC.
second digit.
HINT:
on page DI–267.
Thanks!
