Airbag Reset Proceedure
Got the Airbag/SRS light on. I understand the DTC procedure to attempt to 'reset' the light, but need to know if there is any danger of setting off an airbag when using this process?
I know the reset might not be successful, depending upon what 'triggered' the fault light to begin with, but I don't want to set off an airbag if there any danger of doing that.
Thanks in advance,
Flint.
When I did this I tried a couple of times and it didn't reset after taking of the steering wheel to install a leather steering wheel cover. I found I didn't have a good ground and daisy chained aligator clips to the negative post on the battery.... BOOM worked like a charm.
Worked for me first time
Thanks all! I did this several times without success, counting one, one thousand, two, two thousand...
Wasn’t until I counted using Mississippi’s that I finally got it to work Lol!
^^^^^^ Southern vehicle. You should have known that. ;)
I love this forum, the aforementioned worked!
My spiral cable assembly (clock spring) failed and immediately made my airbag light illuminate. I replaced the broken component with one from a parts vehicle after 2 different China aftermarket parts all did not fit. Do not waste your time with the Chinese garbage on eBay and Amazon, make sure any replacement spiral cable assembly you get has the 6 metal pins for your cruise control.
Exactly as mentioned above, I soldered paper clips to a couple wires long enough to reach the negative battery terminal. Paper clip side was jammed into the DTC. It took me 6 tries to get the correct speed/rhythm of the AB/TC sequence, but low and behold, when I peeked inside at the dash, the light was off.
Sincere thank you to whomever figured this out.
I just did this today on my 80-series but have an extra tip. I placed a mirror so I could see the air bag light while I was grounding the terminals. The light lets you know when you got it right. During the procedure you will see the airbag AND ABS light go on and off but on the 5th step the air bag light will start flashing. As soon as it starts flashing disconnect the ground. here is a picture of how I set up the mirror.
Adding a “modern” idea on how to see your lights flash.
Good idea / have one of those similar tripods.
—— Wheel leather recovered?
— If so, did you use the place in TX or some other vendor?
— In - hand review of the work & quality?
I’m going to have to give this a try since my light has been on ever since I had to take apart my dash to fix some rust around the windshield. I guess I set off the light when I disconnected the PS airbag.
I was able to successfully reset mine on my LX-450.
On the last contact of TC to ground, instead of 5 seconds, I did 20 (arbitrarily) that fixed it on the first go, after ~10 attempts the night before using just 5 seconds (I even tried 5 counts of Mississippi).
CEL is back on today. :mad: I'll get it evenutally though.:)
Here's the Airbag reset proceedure as per CharlieS from about 2 1/2 years ago.
CharlieS:
Hi All. Quick update.
I was able to read the SRS DTC codes, here's the procedure:
1) Turn ignition to on or acc for 20 seconds
2) Using SST (paperclip) jump terminals Tc and E1 of the diagnostic connector (DLC1)
3) Read code(s) by counting flashes of abs light (while ignoring all the other flashing lights)
Codes are gathered by counting flashes, 1.5 seconds between digits, 4 seconds between individual codes. If you miss it, keep waiting, it will cycle again.
Mine was a 54 (Open in P squib circuit) which corresponds to the passenger airbag being disconnected.
I reset the codes and all is well.
Incidentally, the reset Darwood posted works. However it doesn't work if the wires you are using do not have contiuity ( ). I checked my "reset" SST with my multimeter and found that I had a break in my wires. Fixed it and was able to reset it.
Briefly, for the archive:
1) Get two separate longish wires (another SST!)
2) At the DTC put one wire in the Tc terminal and one in the AB terminal
3) Turn the ignition to on or acc for 6 seconds (leave it in on or acc)
4) Go to the wires in the DTC and do the following
a) Tc to ground for 1 second, remove
b) AB to ground for 1 second, remove
c) Tc to ground for 1 second, remove
d) AB to ground for 1 second, remove
e) Tc to ground for several seconds (5 according to the FSM)
5) ABS light should flash rapidly and reset
That reset the codes.
Note, as Darwood says, you need to switch the wires quicky (.2 seconds?) but that is easy to do.
By the time I got to the drivers side my ABS light was off.
Also, make sure your SST (wires) have continuity or this won't work.
The dealer wanted $35 just to read the codes. Then they couldn't
find the "special connector" anywhere. I should've loaned them my paperclip
Glad I tried again. Thanks everyone!!!!
Good luck.
Charlie
Appreciate this info. I have tried this over and over with no luck. Different wires, different grounds with no luck. I am trying to turn off my airbag light. 80 was in storage for many years.
Any mechanic with a Pro level diagnostic tool can probably turn the light off for you but of course will charge you for it. There are some lower priced scan/diagnostic tools that may be able to reset the SRS light. AFAIK the cause of the light coming is when the SRS computer doesn't have power for weeks, months,--- that apparently sets the code.
FWIW and repeating from page one, after the wires were hooked up and a bolt head was slightly sanded to get good ground contact point, is that extremely rapid switching of the wires when touching the ground with no pause in-between (even though most directions say wait one second) worked for me.
Just thought I'd throw in my two cents since I've been trying to get my airbag light off for the last 2 days straight.
After at least two and a half dozen tries of trying to follow the FSM procedure to the letter, especially in terms of time, No luck. After going to the process, It would just continue to flash the number "14" code I had.
I finally got really frustrated and did the entire five-step procedure as quickly as I humanly could. (Tc, Ab, Tc, Ab, Tc (hold)) All of that inside of two seconds total. After about 10 seconds of leaving it on Tc, the airbag light started flashing like a madman and that's it signal that it's cleared the code. Job done.
We'll see if it comes back, But at least I got to sit in my driveway for 3 minutes and look at a dark dash!
Cheers.
--MG
Quick note up front because this mattered more than anything else: I did not wait a full second between grounding TC and AB like the instructions say. Counting “1-100 or 1 Mississippi” was too slow. Moving a little faster than one second but not super fast is what finally made it work. Also Turn ignition to ON, not ACC
First of all, thank you all so much for the information here. This thread absolutely saved me.
I was replacing the high low beam switch on my 1996 Land Cruiser. For the record, that job is a huge pain. If anyone ever has to do it, just buy the entire switch assembly and save yourself the misery.
During the job, I accidentally turned the ignition on while the driver airbag was disconnected. I put everything back together and of course the airbag light stayed on.
I had originally seen the TC and AB reset procedure, but I ignored it because someone told me that on a 1996 the airbag light would clear itself. That is not true. There's a lot of false information for this procedure online. This is the right one for a 1996.
I then made the mistake of asking AI for help. It convinced me the problem was the clock spring and that the airbag light was clear once the air was fixed. AI Sucks. That seemed logical since I had just removed the steering wheel and thought I must have broken or miscentered it. I tested continuity on the clock spring and it tested fine, but I replaced it anyway. As expected, that did not clear the airbag light.
That brought me back to the TC and AB reset procedure. I tried it at least ten times with no success. What finally made the difference was doing the grounding sequence faster, not one full second apart.
Here is exactly what worked for me.
Steps that finally cleared the airbag light:
  1. Ignition OFF
  2. Battery connected
  3. Insert two wires into TC and AB in the under hood DLC1
  4. Run a wire from the negative battery terminal over to the diagnostic port. I used vice grips on the battery negative terminal.
  5. Turn ignition to ON, not ACC (if someone could confirm that I think it would be helpful for everyone I tried it both ways, but I'm pretty sure I had to have the ignition on)
  6. Wait about six seconds
  7. Ground TC briefly, release ((I did this faster than one second per step. Not frantic, just clearly quicker than counting a full second.)
  8. Ground AB briefly, release
  9. Ground TC briefly, release
  10. Ground AB briefly, release
  11. On the final TC ground, I clipped it solid with an alligator clip and held it. : At that moment, I looked in from the passenger side and saw the airbag light flashing, which was a huge relief. I turned the key back on and the airbag light came on for a few seconds and then went out. Code cleared.
  12. While TC was still grounded, I turned the ignition OFF
  13. Remove the ground and all wires
A couple additional notes that may help others:
  • ACC position did not work for me. It had to be full ON
  • I did not wait very long once the flashing started. I turned the ignition off fairly quickly and it still worked
  • Speed of the TC and AB grounding sequence mattered more than anything else
I was honestly about to take it to the dealer because this is my son’s car and driving around with an airbag light made me very nervous. I would never forgive myself if something happened and the airbag did not work.
Thanks again to everyone who contributed to this information. It really saved me.
