AMSOIL dual remote oil filter set-up
I've kind of had my eye on AMSOIL's dual remote filter kit, which holds a full flow filter along with a by-pass filter that filters down to a much finer size. The kit is the BMK13 on found at
https://www.amsoil.com/storefront/bf.aspx
and
https://www.amsoil.com/bypassfilters/instructions/BP152.pdf
The benefits I can see would be:
Easier and cleaner filter changes, as the filters can be mounted hanging down vertically in a convenient spot
Greater oil capacity for cooler temps and greater dilution of contaminants
Higher quality of filtration as a result of the by-pass filter
A possible location to add senders for oil temp and pressure gauges down the road
Does anyone have experience with one of these? Thoughts? Would this be overkill, or do you think it is a good idea?
Thanks for sharing your opinion,
Curtis.
and
Curtis.
