Did you ever get this installed? Any pictures?
.Not to be overly negative, but it just looks like another gimmick to spend money on to me. Having owned a half dozen 62's, many with way over 300k, never had a filter or oil related problem. Toyota did it well enough for me.
Excellent.....thank youwhere was you planning hanging the unit from the hood at? passenger....driver?Hmmm, figure I will try slipping the bottom of a pop bottle under the filter when I take it off and hope that there isn't too much that comes out. Worse comes to worse, I guess an old towel shoved in under them should catch most of the drippings. Another option would be to un-bolt the mount (4 nuts in front of the sheet metal) and swing it up over a pan.
Oh.. i think i will go behind the drivers headlight thenI was thinking passenger side kind of behind the air cleaner, above the coil and fuel filter.....
You'd have to be careful how you run the lines, and likely use some shoelaces or springs or shock-cord to suspend them, but allow for flex when the hood is raised.
Oh.. i think i will go behind the drivers headlight then![]()
But it clearly is pulling out insolubles.
