- Joined
- Oct 31, 2008
- Threads
- 67
- Messages
- 815
- Location
- Napa Valley California
- Website
- www.mosscreekwinery.com
I am doing a Disk Brake conversion from a FJ60 to a FJ40.
How do I swap the inner axel of a fj40 with the into Birfield of a FJ60? (the FJ60 drivers side inner axel is a couple of inches longer than the fj40 housing)
I did not find an easy answer so I decide to start my own thread.
Thanks to a little information out there and a phone call to Georg who is orangefj45 on this forum, this is what I did.
This is what I did using "the Pipe Trick".
I took a 2 1/2 inch stainless steel pipe, a little longer than the inner axel. I place the inner axle shaft down the pipe with the birf bell resting on top of the pipe. Then I pounded it onto the ground with the pipe and birf together onto a a piece of plywood on top of a hard surface.
You have to pound it very hard and the axle shaft comes loose. In my case popped out and hit the plywood. By having it placed on plywood prevents the spline from getting damaged.
