- Joined
- Sep 23, 2003
- Threads
- 355
- Messages
- 2,572
Cracked 2F block-Should I weld?--Pics added
Fellas,
My overheating problem revealed itself as a cracked water jacket. I was losing coolant. I thought it was from the overflow tank.
The crack is about a foot long on the driverside, not obstructed by the EGR line or manifolds. There is a good welder in town that works on engine blocks, mounted or not. What would you recommend? Any experience out there welding blocks? Do the welds hold on these engines?
The engine has 89k, the vehicle is a stock 84 FJ60. Compression is 145 across all cylinders with no other oil leaks or issues.
4/24/05--Pictures added, crack is barely visible inside the red boxes. Note the rusty/coolant residue below the crack. The crack, to my naked eye, does not extend for 15 inches, but rather looks like two 6-8inch cracks.
Fellas,
