Working on my 1975 FJ40......trying to install the rear disc kit from Poser.
I did a search for rear axle bearing and found a few threads regarding removal of the rear axle bearing.
Unfortunately, I did the search after I have had trouble removing it without the SST in the manual. I see several threads regarding leaving the bearings in place if no trouble is evident since they are such a PITA to remove.
I have used a slide hammer (HF version) and was successful at breaking it apart and removing the bearings, but not the race so now I am committed. The axle housing is on the frame and differential is intact with the exception of the c clips removed and axles removed.
I have seen one thread about welding around the race and as it cools it will shrink enough to remove.
Any suggestions on proceeding? I have a mig and can weld it without burning through the race if that will work.
How about careful use of dremmel tool?
