I have gotten everything fixed so far on the truck but there is one out of two noises that is really aggrevating me. One I think is the idler pulley because it has that screaching at idle and take off but good after that (correct me if I'm wrong) and the other is this misterious whistle noise. It sounds like someone blowing a whistle and it doesn't change w/ rpms acceleration or anything. If you choke the engine out it dies with the engine. We checked all the hoses for leaks and listened with a screw driver. It is NOT the brake booster but is coming from around that area so we think. We made sure the exhaust manifold was on good and tight. The resident cruiser guru things its something to do with the exhaust or the carb. I have a 2 barrel webber carb.
Thanks!
Thanks!
