1973 FJ40 Drum to drum
Please don't say I need disks. I stop faster and straighter than other disk braked rigs and I stop totally straight without my hands needing to be on the wheel.
I keep having a repeating break issue and I am totally at a loss at this point. I have replaced the entire system (except for the rear cylinders but they are in good shape) and still it does this . . . .
After driving for a week or two or on really long trips, my brakes tend to slowly build pressure until they finally start to drag on the breaks and I have to pull over and pop the master off and turn the push rod down. This is totally random. I can drive for 300 miles or 3, it totally seems to be random.
Before you say that my push rod needs to be turned down it has been turned down, out, and repalced (the rod is adjusted to where I have to fully slam on the pedal to just about lock up my brakes and this happens even after many different adjustments).
Here is what I have done in the past to fix this problem.
1. new brake master
2. new brake booster – same issue starts up
3. mini-truck booster – same issue starts up
4. now an FJ 60 booster which stops much better but it started up again last night.
5. new calipers in the front
6. brakes adjust per FSM (adjusted to where wheel stops after hard rotation and backed off the required number of clicks)
7. bled and more bleeding of brake line.
8. Nothing is original with the braking system except rear calipers.
I thought I finally had the issue taken care of. I have a new brake master and 60 series booster. It normally stops perfectly and was happier than can be to have a drum brake cruiser that would stop totally straight and stop me when I needed to stop. But a few weeks ago, this new set up started to bind a bit again, in the same manner as before slowly replacing everything. I thought I might need to only back my push rod off a bit so I did. When I put it back together, I had no brakes. So I kept extending out my push rod. I finally extended it out about 2 full turns and my brakes were spot on again.
I did notice that once, right after start up from sitting for a few days, I had a soft pedal and pumped the pedal once and the brakes were good. But yesterday, the same old thing started happening (not as bad), but when I pulled into my driveway and took my foot of the brake and put it in neutral, the rig did not roll back. I went inside for a few hours and came back out to put it into the garage. I started it up, pulled the parking brake and it started rolling back. Obviously the pressure let up.
What is going on here? Remember, front has new cylinders, rear or original but I took them apart and they are in great shape with no leaks or anything that would indicate blow by or leakage. When I have my foot on the brakes and turn off the rig, I get a good amount of pressure push back in the pedal.
There is also no signs of caliper leakage in any of the drums. I pulled them and totally dry.
Are my break pads just adjusted too tight and as heat builds, they expand and start the drag?
Might there possobly be a small hole in the brake line allowing air to enter the system?
Is it a vacuum related issue?
Is there air trapped in my lines that I can’t get gravity bleeding?
Do I need to simply take it to a shop that can use a pressure bleeder since this might be as simple as air in the system?
1. new brake master
