- Joined
- Aug 15, 2005
- Threads
- 776
- Messages
- 5,125
- Thread starter
- #41
the hard lines run about 2 fingers away from the headers and they run down it about 6 to 7 inches. THe hard line curves down towards the axle right at the top of the header and follows it straight down to the mount on the axle and it stays tat close the whole way. I only drove it about 1/4 of mile when the brakes started to bind and sill was able to drive it into my grage. Right away I put my hand on the back of the wheel and it wasn't hot. I was able ot keep my hand there and it wasn't the slightest bit warm, but the brake fluid steamed in the res. cup on the vac. pump.
So I know the brakes aren't hot enough to heat the fuid if I can put my hands on the bleader valve and it was at room temp, but the fluid is warm enough to see a tiny bit of steam. It wasn't boiling with a huge amount of steam, just saw a little wisp of steam for a second in a hundred degree garage. It was very warm until it was in the air for a minute and cooled down right away.
I will move the brake line tomorrow. Once i Released pressure to blead my brakes were working fine so it will ahve to be blead and driven to see if it happens again.
After that, I will have to go with another master if it isn't the heat.
