I am Yves from the Netherlands. At the moment of writing I am 23 years old and like a lot of people on here I really like Land Cruisers.
In daily life I am an electronic engineer and have my own company designing and producing electronics. I have got skills in fabricating, servicing and repairing. I will be repairing, maintaining and building the hundy by myself.
I always like to read Build threads. So this is a place where I can post my progress and people can ask questions. I will be doing some fairly moderate stuff but there will be things people will be interested in.
I sometimes saw these Cruisers on the road and always thought that they were very cool cars. I wanted one myself but couldn’t pay for one. Sometime later my dad was looking for a replacement for his Hilux. He was looking at Land Cruiser 60’s and 100’s.
Together with my dad I was browsing through some cars and the 100 became an even cooler car for me. At this moment I would really like one as daily driver, for travelling and offroading.
After we visited some of the cars for sale my dad decided he wanted a Hilux again. He transports a lot in the bed of the Hilux and that wasn’t possible in a Cruiser.
So that left me with the Land Cruiser in my head. I went back to one that was for sale. It was quite a rough one. It had been standing for two years in high grass and didn’t look very nice. The interior was dirty and smelled bad, rear hatch wouldn’t open, cracked windshield, brakes were sticking, PWR button stuck, timing belt needed replacement (8 years old), some rust. AHC wasn’t working and a lot of warning lights were on. Dis I already say that the interior was dirty and smelled bad?
This was a good reason to get it quite cheap. Since I like working on cars this wasn’t a problem. I drove it home 200km / 125 miles and stored it there.
As you can see in the picture below the rear is low and the front is normal. This is just after I drove the car home when I bought it.
Before I could work on it I should finish my bachelor degree, so I got to work and finished that. Good motivation, it was finished a lot quicker than it would have been.
I cleaned the car, opened the rear hatch from the inside. I had to open it up because the handle inside & outside wouldn’t work. The hatch was also rusted a fair bit so I started looking for a replacement.
The first thing I started working on was the AHC (automatic height control). I had experienced the AHC in some other hundy’s and liked it. I like being able to fit in parking garages and have a few inches of lift “on demand” with the push of a button.
I also like the dynamic dampening and being able to adjust it.
So having decided I wanted to keep AHC I got to work. I already have a thread on that so I won’t post it all again in this one, but I will give you a
link.
EDIT: I forgot to put the link in but @PabloCruise put it in post #5.
In short there was a faulty door switch and a bad alternator + dirty connectors and a broken sense wire. When I replaced the alternator a lot of warning lights went off.
Now that the AHC was working again I could start on all the other things that need fixing.
Painting the grille:
I took apart the sticking brakes, the pistons were badly pitted. New ones are not that expensive, so I installed new calipers in the front. The rear was still good.
Replaced front brake calipers;
Replaced front & rear brake pads;
Flushed brake fluid.
My brakes were sticking badly, the car wouldn't move in idle Drive or Reverse.
At first I wanted to replace the pads and free the calipers, this is how they looked:
With a 24H soak in lots of penetratring oil and a large hammer I was able to get them out.
I cut the half circle off on the left side so I could make more speed with the hammer.
After getting the pins out I got the pads out. Then only three of the pistons would go back, one was stuck.
I took the piston out of the caliper, it was pitted and needed replacement:
Since the calipers had a lot of rust, also around the seals I went with some new calipers. Here is old vs new:
The rubbers on the old calipers expanded and did't seal well anymore. You can see how the rubber is too big to fit:
New calipers on on both sides:
Also bled and flushed all the brake fluid.
Easy job, no special tools needed.
All new pads, 2 new calipers and a flush can be done within a few hours.
Also drove the truck a while (+/-100 km's / 60 miles) for the first time after repairing the brakes & AHC.
Waiting for a replacement upper tailgate, dutch APK (yearly safety inspection), insurance and after this I can drive & daily the truck.
I felt some play in the left hand side front wheel, A good time to repack the bearings and fix the problem. I bought a 54mm socket, fish scale and got to work.
Repacked wheel bearings & greased spindle bearings.
Wasn't done for a long time, no visible wear on bearings.
Used a scale to measure preload, adjusted the nut until preload was between 42 - 67 N (as per FSM).
Greased the needle bearings with a "DIY spindle greaser" (PVC tube, end cap and some insulation tape):
On the left axle (right OK) the groove is a lot wider than it should, is this normal wear for a 400.000 KM / 250.000 Miles Cruiser?
This is the groove with the snap ring installed (left/drivers side):
As you can see, way too wide. FSM states a maximum of 0.2mm / 0.0008 in of clearance.
For now I added a (non Toyota) snap ring to reduce the clearance.
To get the car back on the road I had to fix my windshield. I had a local garage cut out the windshield and started repairing some rust:
My windshield was cracked and needed replacement. There was also rust coming from underneath the window. This was the perfect time to fix that.
Instead of pop rivets a previous owner used simple wood screws to secure the side molding. This caused rust on the A-pillars. There was also rust on the roof coming from the windshield.
With the windshield out I used a rotary wire brush to remove all the glue and paint. I used a flap disc to clean up the bad rust.
When all the rust was gone and there was only clean metal left I degreased the surface and brushed on some rust protection.
There was also rust on visible places. Tomorrow I'll be sanding and spraying on the Toyota 1B1 Champagne Pearl, clearcoat the day after that.
Heres a pic of the rustproofing:
And basecoat:
Yesterday I sprayed the first basecoat. Today I sprayed the second basecoat of the 1B1 colour.
Yesterday I masket quite close to the edge of my repair work. If you spray up to the masking tape there will be an edge.
Today I used some scotchbrite to get rid of the edge and placed my masking tape about 10cm/4in further from the repaired area.
I then sprayed up to where the old edge was to "blend" the paint.
For this work I use a small HVLP gravity fed spray gun on about 1.9bar/28psi at 20cm/8in distance. Fan pattern about 12cm/5in.
Tomorrow is clearcoat day.
Here's the result so far:
On the right side A pillar there was a little bit of paint contamination, but not enough to worry me.
I finally found a new (to me but used) hatch, I also got the bottom part because that also was dented. Here’s a picture of the replaced parts:
I also found some used carpet. It looked a lot better then the carpet that was in my car but was still dirty. I used some soap and a pressure washer (with hot water/steam cleaner) and cleaned the carpet. This worked really well. I let it dry inside for a few days and installed it. I also added a set of gray weathertechs to keep the new carpet nice.
There was one last thing I needed to fix before the yearly inspection, this was the wiper mechanism. It was completely worn out and needed replacement. Here’s a picture of the worn out bushes:
It is not a cheap part but I had everything off the car because I was replacing the windshield. Undo the six bolts that hold the wiper linkage in its place. Unbolt the Wiper motor, unbolt linkage from motor and remove linkage. Assembly is reverse of disassembly.
The car was now going for the yearly inspection and passed. I could now drive it on the road again. I had planned a trip to Sweden/Norway a month from this date. So I had a month to test drive the car.
