I was just looking through photos and came across a picture of my new fusible links. They say "YAZAKI FLWX".
I found this Yazaki PDF:
http://connectors-catalog.sys.yzk.co.jp/cables/pdf/45_FLWX.pdf
I know that people have asked about the specs of the fusible links, so here's what I can gather from the PDF:
It took me awhile to realize that the first column, which I'm calling 'size', is just the cross-section area rounded. The AWG column is my own estimate based on a couple of AWG-to-metric charts.
This is probably enough information to put together your own replacement using local parts, in the event that your fusible links fail and you can't wait for Toyota parts (you do have a spare 90982-08264 in your glovebox, right?).
Code:
Size Strands/Dia. Cross-Section Wire O.D. O.D Color Resistance (Ω/m) AWG
0.5 7/0.32mm 0.5629mm² 1.0mm 3.0mm Green 0.0354 19 - 20
0.85 11/0.32mm 0.8846mm² 1.2mm 3.2mm Red 0.0225 18
1.0 13/0.32mm 1.046mm² 1.3mm 3.3mm Yellow 0.0191 17
1.25 16/0.32mm 1.287mm² 1.5mm 3.5mm Black 0.0155 16 - 17
1.5 19/0.32mm 1.528mm² 1.6mm 3.6mm Gray 0.0127 16
2 26/0.32mm 2.091mm² 1.9mm 3.9mm Blue 0.00954 14
3 41/0.32mm 3.297mm² 2.4mm 4.4mm White 0.00605 12 - 13
