For Sale (WV/DC/MD) Tons of FJ40 parts, shifter,MCs, smog, PS pump.
Hedgesville, WV
Website
www.instagram.com
Hey guys, I hinted at all these parts in my --->> other listing <---.... I am busy with work, so I will try to check back often and respond as soon as i can. I'll ship the cheapest priority mail or whatever i can. Shipping cost will be added once I can get an accurate and cheap quote for you. Local pick up is welcome, I can possibly meet up. I am cleaning out the basement, there is probably more than I am listing here.... I am hoping all of my prices are fair, I probably over paid for a few of these items myself, but trying to cut everyone a deal. This will go into my cruiser fund to get the new garage up so I can tackle some of this rear sill and tub rust, thanks in advance guys, Kevin.
PICTURE 1
Clutch and brake master cylinders $15 each
slave cylinder $15
PICTURE 2
2F carb with remaining rebuild kit $100
PICTURE 3
Early Siamese intake 1BBL heat riser gasket new SOR $15
PICTURE 4
3-speed bellhousing $40
3-speed clutch,flywheel, pressureplate, throwout arm+bearing AS KIT $40
3-speed shifter with knob $50
'76 Disc front 4-speed driveshafts front and rear $100
PICTURE 5
rear hatch latches $20
vacuum canister $10
VSV $15
intake hose clamp make offer
1 or 2F Saginaw power steering pump and bracket $100 Sale in Pending
PICTURE 6
2F radiator support $30
front driveshaft splash/mud guard $35
2F aluminum intake manifold $30
battery tray/mount $35
2F '76 FAN $30
PICTURE 7
Almost complete vacuum shift transfercase kit, plus hi/lo levers for under dash, works great all lines and pieces except actuator cable and shift valve. $100
F.D. knob for cable $40 (its what I paid for it).
Idler arm kit used $10
PICTURE 8
3-speed manual shift linkage, the shifter was cut by PO and I used the Transfer Direct housing (according to SOR). the rest of the pieces are all there. $75
PICTURE 9
early oil pump, from my other listing $65
PICTURE 10
Used F135 1F engine for repair, from my '68. has water pump and fan, oil pan. Has not been torn down, lost compression on one cylinder. If want parts, ask. as it sits $150 and if you can arrange some sort of shipping that works.
Heater Valve is now removed from engine.
PICTURE 1
PICTURE 2
PICTURE 3
PICTURE 4
PICTURE 5
PICTURE 6
PICTURE 7
PICTURE 8
PICTURE 9
img_2815-jpg.1545513
PICTURE 10
I would be interested in the intake manifold if it is not cracked, as well as the fan blade. Hatch latches. Maybe the carb core.
The Manifold is cracked, but but let me know if you still want the others.
I'm still interested.
PKM sent, plus I'm also interested in your slave cylinder for 10 bucks.
PM sent, plus I'm also interested in your slave cylinder for 10 bucks.
PM sent, plus I'm also interested in your slave cylinder for 10 bucks, lemme know.
MUD seems to have developed a stutter. I got 7PMs from two people. Repeats too.
I would also like the heater valve assembly from the cylinder head. You can toss @Downey slave cylinder in my box; I'll cover the shipping. We see each other regularly.;)
I need a Slave Cylinder Boot Only if U / anyone has one / If fellow member Downy's fall's through im 2nd in line Please .....
NO " High-Jack " ...........:poof:
I'm gonna pass on the carb.
I received the 4WD shifter parts the other day, but I don't need the shaft that is for the vacuum shifting valve for the 4WD shifter, sooooo if someone buys your vacuum valve and needs the shaft it's a freebie from me. Gosh I hope this message doesn't repeat 4 times like my last message?????
