Wanted WTB FJ40 (2 Viewers)
Year
1975
  1. 40 Series
Looking for a real solid roadworthy 40. Something with a V8 swap preferably. Kansas area but would travel/ship if needed. Budget around $15k. Thanks
=========== NOTE - These are not mine, contact the seller via the Craigslist Ad =================
1970 Toyota FJ40 - v8 swapped
Yes I know it’s not original, but if you’ve driven or tried to stop an original fj40 above 40 mph, you know that original isn’t always the best.
- mildly built 350 w/ 4 bolt mains and aluminum heads - arp top end hardware - crane roller rockers - aluminum dual plane intake. FiTech EFI, edelbrock efi sump & aeromotive external fuel pump. Oversized aluminum radiator & electric fan. 2-2.5” single exhaust with flowmaster muffler.
- sm465 4 speed w/granny gear. Gone through with new shift forks & centerforce clutch.
- fiberglass tub & front fenders. The rest is original steel. Some paint chips on body and slight bubbling on one of the rear barn doors. Paint is in overall good condition and shows very nicely.
- frame fully por15 coated - new suspension w/ small lift (2.5” suspension lift & 1” body lift)- and Fox shocks - 4 wheel power disc brakes (Wilwood fronts & gm rears) - rebuilt hubs.
- original Toyota transfer case with drum parking brake - rebuilt.
- custom made bikini top & trail cover
Transferable registration in my name
Moved it to storage in our second property in Pa (outside Scranton) so showings can be arranged on weekends only.
1968 Toyota Land Cruiser FJ40. Both Hard and Soft Top. 350 V-8 - $25,900 (Cottage Grove)​
1968 Toyota Land Cruiser FJ40. Both Hard and Soft Top. 350 V-8, Turbo 350 Auto Trans. This is a great running and driving solid FJ but still kind of a project to finish how you like. Winch, heater, wiper, lights everything works but speedometer not hooked up and blinkers don't always work. Body is pretty straight and solid there is some rust down low on rear under tail gate - Shown in pictures. Tube rear bumper and extra doors, Newer soft top, Hard top is correct for year but purchased separate so is not same color but is good and solid. 4" lift with like new 35" tires and matching spare, new shocks and front end alignment. Motor is not suppose to have more then 10,000 miles but have no records for that. It was taken to mechanic before we got it and had $700 spent on tune up, Carb rebuilt and just going thru checking all mechanicals, so it runs and drives great. Have a folder of receipt but not for everything that has been done. # B-1826 $25,900
1979 Toyota land cruiser FJ40​
$25,500
1979 Toyota FJ40 Landcruiser Up For Sale!I have owned this rig for 6 years and our family has simply outgrown it after creating many great memories in this fun truck. It is ready to enjoy right away as is or you could take it to the next level of restoration to fit your needs.*Chevy 350 Engine w/ 4 Speed Manual transmission*2 Speed Transfer Case*33” Bf Goodrich Mud Terrains at 90%*Mickey Thompson Classic 2 Wheels*Extended range fuel tank installed*Grease-able Shackle Leaf Springs *Aluminum Racing Radiator Upgrade*Winch Included*Battery Master Switch installed and trickle charge cable for storing it over the winter, etc*Hi-Lift Jack*Hard Top & Ambulance Doors Included if you want. The hard top and doors are complete but the common rust repair on the door bottoms needs to be done. I have the patch panels if you want to do this or have it done. I have always left the top off and had it garage parked.
1967 Toyota land cruiser​
$13,800
Seller's Description​
1967 Toyota FJ40 *Project*Newly rebuilt 302 V8New AX15 5-speedFrame sandblasted and powder coatedRedline Cruisers 2.5” suspensionNew 33x10.50 Mickey Thompson Baja MTZNew wheels with hub capsInterior raptor lined New wiring harness
1978 Toyota Fj40 Land Cruiser​
$18,500
Selling the 78 FJ40. We were trying to hang on to it but It’s better to sell it than let it sit around. Doesn’t get driven much anymore. The body and chassis are rust free, being a Arizona and Texas vehicle has saved it from being a rust bucket. It has a 69 model Chevy 350 and a Th350 transmission. Freshly rebuilt carburetor. Recent tune up. The 4wd works great. Brand new Rancho 9000 shocks and steering stabilizer. Has power steering, power front disc brakes. Heater works great, It’s a really cool vehicle that gets a lot of attention and the value of these are just increasing. 18,500. Texas title in our name. Located in Midland. No trades. Will delete and not respond to is it still available
Very clean driver grade 1975 FJ. Privately owned for about 10 years. Garage kept and driven a couple times a month around town. Never off road. Prior owner did a very nice restoration. V8 chevy with 2500 miles. 4 speed manual. Good year that never requires smog. Nice quality driver that runs well but just doesn't get used enough, so time for someone else to enjoy.
He's been trying to sell this for a long time, now $23k
Clean title, non op.
All parts new or rebuilt... below is a short list of what's on the cruiser...
- Everything is polished billet, chrome, or paint
-3/4 aqualu tub aluminum
-Aqualu firewall and windshield aqualu aluminum
- aqualu aluminum fenders
-aqualu aluminum aprons
-Aqualu aluminum grill
-Aqualu aluminum 1/2 doors
-Aqualu aluminum rear tailgate
-painted full cage
-black suede sparco seats
-warn full float kit w/ disc on rear axle
-wilwood disc front with vented rotors
-painless wire harness
-Late model programmable fuel injection system
-new gauges in billet panel
-Supercharged 350 with aluminum Edelbrock heads
-Fresh So cal speed shop 700r4 tranny
-new in box magnaflow mufflers
-4plus dual rear swing out painted to match frame with cooler carrier
-Saginaw p/s conversion
-gm tilt column
-painted full cage
-new factory hood
-aluminum radiator
-polished transfer case
-locar shifter
-22.5 gallon fuel tank painted
Tons of other parts in boxes that go with it.
Tons of other parts....
The pics don’t really show how much $$ has been spent to get this unique FJ to this point. It's all there, ready for final assembly and body paint. Too many projects and not enough time to finish, although I am still spending time and it's more complete than the pics show. Someone will end up with a very unique and cool rig. FJ's of this caliber go for well over $100K finished.
Basically it needs brake lines connected, fuel injection system connected, and wiring run.
Possible trade up/down for car, truck, motorcycle or RV. (No boats and NO PROJECTS:)
WILL NOT RESPOND TO TEXTS ASKING - "IS IT STILL AVAILABLE"
1962 fj 40, sbc conversion toyota 3 spd. Front power disc conversion. Has a soft top not sure if all the parts are there never installed it. Have the full doors with glass need paint and rubber goods. Have a sm465 with aa for the 3spd transfer. Some other spare parts that go along with it. Lost interest in project drivable mostly complete still needs some work motivated seller. Call or text.
Doesn't need much to be driven.
1971 TOYOTA FJ40 "CUSTOM" - $35,000 (Show Low)​
Frame off restomod just completed with a rebuilt 350 V8 with Sniper fuel injection, TH350 Automatic transmission and due to the bigger engine and bigger wheels and tires, a new Orion upgraded transfer case and twin shifters from BTB products were just added at a cost of $6800. (No more whine or future problems)
Frame and axles sandblasted and painted with Upol satin black frame paint. Sand blasted underside of body and coated with Rhino tuffcoat. Coated interior of body with Rapter bedliner Body primered and painted with 3 coated of Silver rush paint and clearcoat. Replaced tailga with Barndoor style, added new painted custom dashboard and front fenders. All new body mounts. Gas tank cleaned and reinstalled. Replaced all belts on engine, rear pinion and axle seals. Added new stainless steel exhaut system, Flaming river tilt steering column and new steering wheel and horn. All new wiring harness.
Installed new door handles and mechanisms, custom roll bar, power steering, power brakes, and steering stabilizer and new disc brakes. Added battery tender, electric heater under dash, new Dakota VHX instument cluster in dash along with new Pioneer AM/FM CD Stereo mounted in glovebox with new waterproof detachable speakers behind front seats and new antenna.
Installed Rough Country 4" suspension lift, new BTB Produsts front bumper, shackles and D rings front and rear with new 2" receiver hitch and wiring. New tail lights and front KC lites and parking lights. Replaced side mirrors so doors could be removed. Added custom license plate bracket and lights, chrome hood vent, fire extinguisher, bikini top, never used, new storage cover, and color matching full steel doors. .
Installed new Warn #8274, 9000 lbs. winch, ($3500), 4 brand new ICON 16X10 gloss black wheels with 4 new NITTO Trail Grabber M/T 285/70R16 Tires.
If you're looking for the max in an FJ40 for rock crawling, daily driving, off road or Car show, this is it.
Clean Arizona title in hand. Have documentation on build. $35,000 OBO Call or text: 602-762-630seven
=========== NOTE - These are not mine, contact the seller via the Craigslist Ad =================​
Solid S Cal FJ with 350 V8, auto, 4 WDB, fuel injection, rebuilt suspe - $34,995 (Laguna Beach)​
This rust free FJ45 runs and drives great with a strong fuel injected Chevrolet small block engine and 3 speed automatic transmission, The Toyota has rebuilt suspension, new seats, seat belts, new dashboard gauges. four wheel disc brakes, good glass, new window felt and channels, no rust, electric winch, aluminum wheels, new wiring and much more.
Here is a link to a video test drive:
This vehicle is exempt from California smog requirements, comes with a clean and clear California title.
Low rate financing is available with approved credit. You can apply directly on our website (www.lagunaclassiccars.com) by clicking on the "Financing" tab.
We can also arrange delivery to almost anywhere.
Laguna Classic Cars & Automotive Art Inc.
2171 Laguna Canyon Rd Laguna Beach CA
(949) 715-4555
