- Thread starter
- #101
Thanks for the feedback guys.
I've verified ALL ohm measurements and gap measurements and ALL are within spec. Since I don't have spark now, I'll check spark from coil again, but I'm pretty sure I'm getting spark to the distributor. Rotor & cap are new, I even tried putting in the old ones to make sure that wasn't it, didn't work.
I've done these things several times now. I'll bet I've installed the distributor 8 times already.
Next 2 steps:
1. DISTRIBUTOR NOT RIGHT: I'll turn 360 degrees and try reinstalling the distributor, if it doesn't go in right, I'll rotate 360 again and try. THIS HAS GOT TO BE THE ISSUE! It is the ONLY thing that is not right. All other measurements have been verified and are correct. Upstream (coil & ignitor) has NOT been removed, so most likely not the culprit.
2. Spark plug gap: I usually don't gap the plugs because they are pre-gapped, but I'll pull the plugs and verify gap. With plugs out, combustion chamber can air out to make sure she's not flooded.
Click: Something new did turn up yesterday. When I turn key to ON, I get a click in the engine area. I'll see if I can repeat this today. I don't remember this happening before.
Next 2 steps:
