If you have spark, then you should be getting fuel as they are controlled by the same EFI circuit. If you crack loose the cold start injector pipe at the banjo fitting JUST A LITTLE BIT after cranking the motor, there should be fuel pressure. As in fuel should spray out. If you're not getting fuel there, then the fuel pump is not running. If you are getting fuel at the CSI, then we need to go deeper.
