- Thread starter
- #61
Yes I checked each fuse out of the truck and they all beeped good
I disconnected the battery and the FL... I have neg at neg post ant touched each post in the FL but only one had a reading
Remove the fuse box cover from covering up the battery post so we can see what you have or have not hooked up.
What is the big lug hanging in mid air to the lower right of your red test lead in the last picture?
What are the two black lugs/wires to the left of the fuse box cover?
That's the updated ECU so that rules that out
Do still need to check spark. If the CEL indeed works, then we need to verify spark during cranking.I'm all out of ideas, should I replace the ecu? @slow95z
I don't see the cut wires.
Then I would look to make sure all the plug wires are plugged in and there is a wire that goes to the distributor, make sure that one is plugged in. It's kinda by the PS reservoir.No alarm, there was one but I cut it out when it started messing with my door locks. I can get a better picture of the cut wires tomorrow. I'll try the spark plug too.. if I dont get a spark should I look at the distributor next??
