Does to me, they burn down...It's a 94 if that matters
He has no power to the ECU that won't help solve the problem correct?Do you have a multimeter to check battery voltage?
Also may look at jumpering the fuel pump to hear it run, through the relay.
Correct. So how do we check systems?He has no power to the ECU that won't help solve the problem correct?
It cranks. Does not fire.
Oh.....Have you EVER unscrewed the two screws on the AFM/MAF/Whatever on the intake air hose and pulled on that harness?
check for spark.
Do you have a timing light?
Only thing we're not sure of is if the CEL bulb actually works. OP does not recall ever seeing the CEL lit.Guys,
With no CEL this engine will NOT run. No need to crank the starter.
Check fuses with a meter not your eyeballs.
Check for +12 on the brass colored phillips screw in the fusebox under the hood.
Check for +12 at the diagnostic connector on the firewall.
No +12 at the AB terminal on diagnostic connector.Guys,
Going through all the fuses in the under hood fuse block.No +12 at the AB terminal on diagnostic connector.
Is +12 at screw in fuse block.
Guys,
You PULLED each fuse and checked it OUT of the truck, correct?Guys, how do I check this one? The normal fuses under the hood and in the cab all are showing good with the meter.
You can check the fusible link with the meter.Is there a way to check the fuseable link with the meter? 1st time I've ever used a volt meter sorry if it's a dumb question
