Then you can only call me on the weekends......
dont forget i have your cell number
during the week i give advice,on the weekends its pure trash talk. i could spam this with pointless memes if it helps
but no, i would suggest the same thing that has been posted. if not the FL then move to NSS or fuel issues.
Remove the high/low pressure part and see if that helps. Can't remember what it's called right now but that can helpMy gut says fuel, what should I check??
Without a CEL, nothing will happen. That tells the ECU that it's ready to run.My gut says fuel, what should I check??
Swap out the efi main relay under the hood. Should be a spare in the driver's side kick panel if you need one. Think that and the am2 fusible link is your best bet for no cel. Without cel light you have no ecu which means you have no fuel or spark. You can jump those fusible links with a wire to make sure you didn't get a crap set of links.
The one that has the same part number.I see 2 in the driver foot well, which one can I pull to swap with the one under the hood ?
I think one is a door relay and a tail light relay so it doesn't really matterI see 2 in the driver foot well, which one can I pull to swap with the one under the hood ?
Call @slow95z .........
He had a new set, then just replaced them in the last half hour with another new set. No change.You jumped the links yet? What year is this?
