Wondering about my birfields (wear)
Norway
Hi all, and thank you for this community.
I’m doing front axle rebuild and have just taken apart the Birfields.
They looking pretty worn (check pictures).
It’s kinda a daily driver, so at this moment I haven’t got the time to wait for new joints. And it’s also a high cost at the dealer in my country.
Are they completely shot? Truck has 512.000 kms.
I'm not a mechanic, but I have serviced my front and rear axles. My birfields were a little less worn than yours at just under 250k miles. I didn't have the nicks in the cage like yours do but I did have the wear grooves in the star and wear marks from the ball bearings in the cage. If you don't have the money to get new ones I would reinstall these, making sure you install them to where the smaller of the two wear grooves is the one being used. Run them until they start to click.
If they ain't ratcheting (popping on sharp turns) start a savings fund and run em!
If they don't click I'd run them.
Thanks for the answers.
Yeah they have chips and nicks in every hole of the cage. I may have noticed some clicking at sharp turns but not extreme.
Anyway, they will stay in there for the next knuckle overhaul interval. Which is what for a road daily driven vehicle may I ask?
I wouldn't worry for street, in 4wd they carry torque, that will be when they grenade.
don't drive like a tard you should be good.
look up rcv in the states
Are they completely shot? Truck has 512.000 kms.View attachment 2736556View attachment 2736557View attachment 2736558View attachment 2736559
That's heavily worn and I'm sure they click hard in turns.
Since you're throwing it back together regardless, swap sides with the Birfield and cage left to right so the power side will be on the opposite side and then they will only click in reverse.
Thank you again.
Will start a savings fund, and get new ones in at the next rebuild, or sooner(!) greased them up very good now, was very little grease in there when I opened. Switched sides.
As you can see from the picture below, passenger side really needed a new axle seal. Funny thing is that I just had that hub out to replace some broken wheel studs. Started leaking diff oil right after. Strange.
Update time.
Job finished. The other side has what looks like a OEM birfield joint. For all I know its the factory one. A lot less wear. Repacked both thoroughly, did not switch sides. and no clicking at turns so far.
Guess what Toyota Norway wanted for a new OEM birf? $2535(!) So next rebuild I will buy two Chromoly for less than a third of the price..
Passenger side may just have had the most worn out lower trunnion bearing in history. And some white plastic stuck in it. Check pics.
Anyway, thanks for the help with this rebuild.
PS: have struggled with the car stalling when turning steering wheel at low rpm. After the new trunnion bearing, that problem is gone. Just saying, if someone else struggles with the same.
Update time.
View attachment 2739321View attachment 2739322View attachment 2739323View attachment 2739324
My trunnions were shattered when I pulled them apart from the PO.
Don't buy chromoly shafts. Get the RCV OEM replacement shafts they will be better unless you're doing rock crawling.
also check into PartsSouq as a supplier - almost guaranteed to be cheaper than $2500
or get used birfs from a European shop or on Buschtaxi or similar sites
Yeah, I'd personally go new genuine if you can afford it. Current part number is 43405-60120. Partsouq has them listed for $370.72:
Unfortunately out of stock right now through them, but I expect they'll have them back in soon. If you're prepared to wait longer for postage, Amayama has them in stock currently for a range of prices depending on which source you pick:
Most of the sources through Amayama are more expensive than Partsouq but there's one out of the UAE listed for $247.42 right now, which is pretty good if you're only after the one.
That part number corresponds with a non-ABS truck. If OP has a 1997 model, didn't they all have ABS brakes by then?
Not outside the US. My 80 was made in mid 1996, no airbags, no ABS for example. There were non-ABS models available right until the end of production outside the US I believe. That said it's a good point, if there are different birfs for ABS models, need to make sure the part numbers are right.
43405-60070
This ^^ is the ABS birfield part number (the updated longer spline). I just bought a few from the dealer for spares, I wish they werent so expensive.
The difference between ABS and nonABS birfs is the toothed reluctor ring.
You can remove and replace the ring.
I've purchased CVs that came with the ring loose in the box. Fit it yourself as needed.
Partsouq list some Japanese made alternatives for as little as $47 for HDK
Update time.
I agree with buying chromoly rather than OEM. Even if they wear faster who cares, its still cheaper and the service interval if followed puts you in there regularly with respect to birf lifespan anyway.
I've got over 150,000 miles on a set of Nitro chromoly birfs that many here no longer like but what ever. They click really bad at this point and I have a new set ready to go in. They have never seen a tire smaller than 35 and are currently turning 37's with a turbo'ed 1FZ. Have not broke yet.
As you're in Norway is your truck part time of full time 4x4?.
