I've searched for hours over the past week and have seen MANY threads about not having spark. I've yet to find one that answers my question, though.
3/1976 FJ40 with 2F engine.
It ran a week ago and then I started replacing some of the old, awful-looking wires a PO had installed. I DID NOT do this scientifically and change only one variable at a time testing the system after each change. (All together now: "Well, that was dumb!")
So this is where I am: The engine cranks (both from the key and from the remote starter I borrowed) but will not start.
I hear the fuel cut solenoid clicking when the key is turned on. There's fuel in the tank and it's in the window on the carburetor. Fuel is not the problem.
When holding the main coil wire (to the distributor) next to a ground there's no spark. Multi-meter measures 12-point-something volts, though. When cranking the engine with one spark plug removed and grounded to the head (wire still attached) there is only the weakest spark noticeable. I've got 12 volts at the contact points when open and almost none when closed.
Spark plugs have all been cleaned and re-gapped to 0.031 inches. There is a new ignition switch, distributor cap, rotor, points, plug wires, coil, and ballast bypass resistor. The engine ran fine after the ignition switch, cap, rotor, and plug wires and resistor were replaced two weeks ago. The battery was brand new a little over a month ago, though it is weak from all the unfruitful cranking. It currently is measuring 12.06 volts at the terminals.
This cruiser does not have a condenser installed (but it ran fine without one). I'm not sure if it's supposed to and truth be told, I don't know what a condenser does. (Besides condensing . . . something ... probably electrons or some such nonsense.)
The coil barely failed the resistance check in the manual so I got a new one from Pep Boys (the only place that had it in stock). I just now went out and tested them both and both of them failed. Dammit!
Old one (Nippon Denso) primary coil 0.7 ohms (pass). Secondary 9.06 k ohms (fail).
New one (BWD Select) primary coil 1.0 ohms (fail). Secondary 10.66 k ohms (pass). Can this really be the issue? If I'm going to spend another $30 on a coil I might was well get one with an internal resistor and then buy one of those Troll Hole electronic ignitions I've come across in my hours of dredging the forums.
I have checked, re-checked, and re-checked again, all the wires I've changed. They all have continuity, and go where the FSM diagram says they should. Every ground I've tested tested okay. I've cleaned any contact that was dirty with a wire brush or 1000 grit sandpaper.
If I crank the engine for more than 10 seconds or so there's a little bit of gray smoke that rises from the
starter end of the big red wire that attaches from the battery to the starter.
Last night I "hot wired" the coil to the distributor and still had the weakest of sparks. (It was coil (-) to wire that goes into the distributor's points, and black/yellow wire from ignition switch and black/yellow from starter to (+) on coil.)
I even drew my own wiring diagram of all the wires I recently changed to see if I would find an issue with the new wiring which I hadn't seen when staring at the 3-page FSM schematic.
The thing labeled "what is this?" is wired to the igniter. It appears to be made of ceramic and has "15H 12ΩK MICRON62" written on it.
I don't know if this diagram will help but this is what my ignition system currently looks like.
Thank you all in advance for your help! I KNOW I can get this running again with your brains. Fire away with your questions, etc.
