Are the ampere ratings shown for the fuses or the conductor size? The information under the node appears to have been added afterwards. The reason I ask is that I believe a fusible link will not have a true ampacity rating other than one that is shown to protect the conductor insulation (I don't know and is the reason why I am asking). That rating (insulation) is far lower than when a conductor will actually fuse. A small conductor, as an example may be rated for 30A (to protect conductor insulation) and a fuse rating (melting point of the conductor itself). Depending on the amount of current available (short circuit current which is essentially based upon the size/output of the battery).
The ampere rating of the conductor (before the conductor insulation is damaged) would not only be based upon the conductor diameter and conductor type but the insulation rating, the ambient temperature, as well as other environmental conditions. The point at which the conductor will fuse will be fairly constant, regardless of the above but will be influenced by length, ambient temps and conductor alloy, time as well as available battery current.
A conductor used as a fusible link has disadvantages, namely that they are harder and more expensive to find. A fuse can be tailored to fit a specific application and are easier to find and replace than the link.
You pretty much lost me with this post, it might be me, I have had bits of my brain removed.
First the fuse must be capable of carrying the amperage that will be drawn by the part needing it and this alone varies for example, a 100 watt fuel pump in theory will need to have a minimum 8 amp fuse, that is 100/12 = 8.33. But as the pump only tends to be running when the engine is running then the amperage the fuse would need to carry during normal running condition will be less for example, 100/13.8 = 7.2
Sounds simple enough but unfortunately this is not the case, the pump has a start up load, there will also be a slight voltage drop on the cable over the length of the vehicle, so the cabling choice from battery - fuse - switch - relay - pump would be typically expected to be capable of carrying around 16 amps, so to fuse this circuit correctly would be a rating of 10 amps, this rating would for the typical vehicle run the fuel pump under start up conditions, be sufficient for continuous running and a 16 amp cable would be safe in the event of a short circuit protected by the fuse, and assuming we are using my example of the fuel pump, then voltage drop to the pump at the rear of the vehicle would be minimal.
In simple terms a fuse should be rated at being lower than the cable size but large enough to carry the load under start up and normal running conditions.
The use of fusible links on older cars is purely a case of being right at the battery positive terminal, in other words the safest place they can be, modern cars now typically place a fuse box on top of the battery using midi fuses again right next to the positive of the battery.
Regards
Dave
