Winter is coming - Cheap(ish) preheat options for the 1KZ
JDM Journeys
Moderator
Calgary, AB
As usual, as winter turns to fall and temps drop, there's a lot of talk about diesels in the cold, especially if you are new to winter dieseling... So I thought a run down of my experiences with preheating methods might be helpful? This is borne out of 18 years of JDM diesel experience in temps that can get down into the -40's celsius, which coincidentally, is also -40F, LOL. :cold:❄️
I'm not going into webasto, eberspacher (sp?) etc. These are the best options, but also spendy.
I've used almost all the 'quick' options. In order of efficiency from best to worst, here's what I've found:
1. Frost plug heater: puts a heater element in direct contact with water jacket. Efficient to heat the block, and gives you heat through your ducts in minutes... but you have to pick the right plug, and orient it exactly right in the block. There is potential for leaks at the oring, and if they're plugged in for long periods, the element tends to burn out over time. They're also a right royal pain to install. If you don't knock the frost plug into the water jacket AND overtighten the wing nut, then you're probably good to go. Overall best bang for buck. I didn't find a definitive answer as to WHERE it should be installed on the 1KZ or how it was clocked in the block, even though the diameter seemed to be the same as the 1HZ and other diesels. Ultimately, on my Prado 90, I went with option 2.
2. Lower rad hose heater - not as efficient as block heater, but does same job via the lower rad hose. Needs to be installed in a vertical length of the LRH. Coolant gets through the "jiggle valve" and eventually the partially open thermostat, contrary to what naysayers preach, and it does work. It's what I currently have on my 1HZ and previously ran on my 1KZ. To those who say these "don't work" I have thousands of starts at -30 celsius and below, that say otherwise. I find you have to plug this one in longer than a block heater to get the same result. Pros are ease and universality of install. Cons are that you need a straight vertical run of hose, and cutting a hose is another potential leak source. Additionally, the hose tends to wear quicker at the contact point, so keep an eye on it, and maybe replace it sooner...
3. Oil pan/pad heater. I see this as supplemental. It does heat the oil, but the water jacket is still freezing its butt off. It might make the difference between start and no start on a seriously cold day, but I haven't seen it make the start less smoky, or much smoother than without. Certainly does your engine a favour though. Downsides are many oil pans are fluted, which makes it sometimes difficult to adhere. Pick the size carefully. I think these are even more useful on an auto trans sump. But that's assuming you have an auto, and I try not to. LOL. In combo with frost plug or LRH heater I think this is a good idea. But on it's own? I'd go with option 1 or 2 first.
4. Magnetic sump heater? Not sure how much utility these have. We've never seen much difference. Perhaps if you have a nice flat sump?
5. Battery blanket - puts a wee bit of heat into a cold battery - not a bad thing, but if you're plugging in to mains, I'd heat the battery from the inside with a charger rather than dumping heat around the outside. Not worth the effort to me...
There are also convection types that aren't THAT much more expensive than the ones listed here, but they do require more room for install. I know folks who've had good luck with them, but I haven't used one so can't speak to the experience. Maybe Darren can pipe in and give a quick lesson on why it is a good way to preheat your diesel? @Rigster ? School is in!! ⛄
So in summary, if you want to have a smooth winter diesel starting experience? Aim for a clean/fresh fuel filter, synth oil, antifreeze that's been tested, winter diesel (obviously), and some sort of preheat method if you can plug in. Additionally, proper functioning glow plugs, clean grounds, and strong battery(es) will make life easier.
Doesn't hurt to carry some sort of antigel additive too,, in case you get some freezing as a result of a fillup...
Hope this helps someone? We went until yesterday with NO SNOW but we now have around 25 cm on the ground and more to come. 🥶
Cheers all
Phil
Thanks, Phil, for the share of your experiences with the various iterations of warmy-uppy devices. Thankfully, we do not see much REALLY cold weather here in the okanagan. The most cold we tend to see is a week or two of -20C temps overnight. That said, I can concur that the block heaters tend to work the best.
For where I live the little 750 watt circulating heater is sufficient so that my Land Cruiser starts without any stumbling or smoke unless it actually gets down to the -20C range, then it will complain a bit, and smoke a little on startup. The nice thing is, that you are blowing heat instantly, nice if you need to defrost. You DO need to remember whenever plugging it in, you have to have the heat in the cab opened so the antifreeze can circulate through the engine.
There are larger wattage ones as well, for those in colder environments, otherwise, I am pretty happy with the circulating ones, though if I were to do it over, I may want to get the next size up in wattage. :cheers:
Thanks for the post, i am from Alberta too , what kind of Engine oil you using? do you switch oil type between summer and winter?View attachment 3508557
I do switch. I run Rotella 5w in winter and 15w in summer. Sometimes 10w in between, depending on the weather and my interval. I log a lot of miles.
Welcome! This appears to be your second post? 90 series is not long available stateside so not a huge store of info here yet but that's changing. If you ever pass through Airdrie, give me a shout!
Welcome! This appears to be your second post? 90 series is not long available stateside so not a huge store of info here yet but that's changing. If you ever pass through Airdrie, give me a th
Welcome! This appears to be your second post? 90 series is not long available stateside so not a huge store of info here yet but that's changing. If you ever pass through Airdrie, give me a shhanks for the answers.Glad found a online community with Albertans here.i read some of your posts. They are awesome and very informative.
Right on. Thanks for the answers.Glad found a online community with Albertans here.i read some of your posts. They are awesome and very informative.
