Why did you choose your front bumper? (3 Viewers)
I remember seeing an ARB bumper that was called Classic of something like that, but I only see the Deluxe listed on various sites.
There are a number of them. No upper bar, small chrome hoop, and full bull bar for example. I suggest reaching out to your local brick and mortar vendor.
Slee--but I spend most my time in CA and AZ. BTW, just changed out the rear to a slee and removed the resonator and moved the tail pipe to just behind the tire--better angles going up and down.
Any 100 owner or any picture we can reference with a Dissent bumper paired with ARB AR32s installed in the front?
Curious about how it sits on the platform and the clearance left between the front grille to the backside heat sink of the lights and front edge of the bumper..
It was available locally (on sale) at the time when I need to purchase it. I decided my first bumpers to be more of a learning experience about what I really like.
It is difficult for me to make a decision about a bumper wihtout actually seeing one in person. That's where going to a meet can help.
So I Just followed the bog for now and may change later on when I have more experience.
Before I buy another bumper, I will want to see how it looks on the back side and the installation instructions and a wiring diagram. Otherwise, no go.
If you ever sell ill be first in line!
I hit one in a *low risk state*, where I had a 0.45% mean probability of hitting an animal. Those of you in a medium or high risk state would be wise to consider getting an aftermarket bumper.
Useless side note: I really wish they would produce these figures with probabilities instead of odds, the former of which are much more intuitive for the layman...
Map needs to be done by region or county in order to be meaningful. I guarantee you the odds of an animal strike in my area of Texas is MUCH higher than suggested (statewide).
Slee front (and rear) here - love the build quality, the clearance, and I've seen a couple of pics of Slee bumpers after accidents or impacts - they worked impressively well.
I've been happy with my Slee front and rear bumpers. Might not be the most "high clearance" but I'd say they are amongst the most robust. And that philosophy is really in line with the 100 series. Maybe not the most graceful but the big girl gets it done. I've had them for probably 12-15 years and if I was to re-powedercoat them, they would look new. I also like the easy access of the winch.
I can attest to how robust the Slee bumper is. I was hit head on and it barely scratched the bumper. Other guy's truck was toast.
full
full
I showed my wife those photos when you first posted them and it went a long way in convincing her we need a new bumper to protect the truck and the family inside!
@CORunner sorry your truck got slammed like that, glad you are okay.
Did both airbags deploy? Its hard to make out if that is airbag material on the drivers side.
Bumper looked unscathed... surprised your roof rack held so well too.
Yep, both airbags.
I was stopped at a stop light and wasn't moving, so I think the lack of momentum probably helped keep the roof rack in check. I swapped that rack onto my new Cruiser and it lined up fine.
I have this ARB, probably circa 2017. Thinking about replacing with a Dissent to trim some weight. Anyone know what my ARB weighs? I'm guessing a lot more than the 65 or 55 lbs for the aluminum Dissent (original and low profile respectively).
HA! Does ARB even publish those numbers? How big is your winch and are you still wrapping the spool with cable or synthetic rope?
I put mine on myself. So not crazy heavy. Certainly under 100lbs. But there are frame caps and the steel plate below that add up, too.
It is a not a LC100 but you get the idea -- the TUFF bar is a VERY heavy steel bar. The steer which end up in the tray of the vehicle is no lightweight. The driver survived but not the steer nor the vehicle.
I have not had the severe experience shown in the first pic above!
I do have the ARB Deluxe Bar for LC100 2002-2007 ARB Part Number 3413190 fitted to my vehicle as shown in the second pic above. This includes compatible mountings for the Safety Restraint System (SRS), alias airbags. Official ARB websites are unhelpful -- seem not to reveal weight information even to us locals!
Several times I have asked mechanics at Australian ARB dealer workshops what they think is the weight of this bar. The answers varied between 70 kilograms (154 pounds) and 80 kilograms (176 pounds) nett addition, after the plastic bumper and related attachments have been removed. This weight excludes winch, sidebars, sliders, lights, radio aerial etc.
The weight given by Amazon USA for the same item is 176 pounds (80 kilograms) – but maybe this is the shipping weight including packaging etc -- -- Amazon product ASIN B004LQGB4S
When I look around various Australian websites for different steel bullbars, the estimate of 80 kilograms (176 pounds) is most common – so that is the guesstimate I use when adding up the contributions to the allowed overall vehicle weight, called Gross Vehicle Mass (GVM) in Australia -- probably similar to Gross Vehicle Weight Rating (GVWR) in USA (?)
If someone on IH8MUD actually has weighed one of these things out of the box on bathroom scales, that would be really good factual information.
Aluminium certainly gives a big weight saving. I had a Toyota-supplied aluminium bar on my previous 2002 LC100 and had a few animal strikes with that bar – mainly mid-size kangaroos, maybe 50 kilograms (110 pounds) at around 100 kilometres per hour (60 mph). It was only just OK – a few marks on the bar, pushed it back towards the body a bit, not a big enough impact to cause airbags to deploy. I would not want to be travelling faster or hit anything bigger with that bar on that vehicle.
For me, reducing the risk of the vehicle being disabled in remote places is the main purpose of the bar – do not want the cooling systems, fan, waterpump, electrics, etc -- being smashed (nor the A750F transmission cooler nor the turbodiesel intercooler). When my 2006 LC100 came along, conservatism drove me towards the steel bar despite the weight penalty, just for a little more protection and risk reduction.
Ultimately, panel damage is acceptable to me – meaning that panels etc just cost money to fix. Damage to vital systems and immobility is unacceptable – meaning that being stuck with a disabled vehicle while awaiting rescue/recovery in remote or difficult-to-access places is no fun at all -- especially if family are onboard, even worse if there are injuries. Such an event would never be forgotten nor forgiven!!!
I liked the style of the ARB bar in the second pic above because the secondary bar which runs across the front below the lights creates a smaller gap, makes it a bit harder for an animal to fit through. So far, it has done the job.
That said, there are limits. Travelling at say 100 kilometres an hour (60 mph) or more and hitting a steer weighing say half-ton to one ton snoozing on a warm road or wandering around certainly will bend the vehicle regardless of the nature of the bar. It would be very, very lucky for the vehicle to remain driveable. The main purpose of the bar in that situation is to minimise human injury. The measure of success is all occupants being able to walk uninjured from the vehicle. Even worse is hitting a tall or jumping animal which comes over the top of the bar and through the windscreen – how horrible this can be does not need any description!
Here is a crash test of a LC200 – no bullbar, not quite the same chassis as LC100 but not that different, similar enough to give an idea of damage after crash testing against an immovable solid object at standard test speed 64 kilometres per hour (40 mph):
ANCAP Crash Test Report:
https://s3.amazonaws.com/cdn.ancap....e15f54fa78f752c4f4021/original.pdf?1445569314
ANCAP Crash Test Video:
Toyota Landcruiser (Aug 2015 – onwards) Crash Test Results | ANCAP - https://www.ancap.com.au/safety-ratings/toyota/landcruiser/c30fdb
[ANCAP refers to the Australia New Car Assessment Program and is Australia’s independent vehicle safety authority comprised of motoring organisations and Governments, independent of vehicle manufacturers and independent of after-market manufacturers].
This TJM video linked next below shows a few laboratory tests on bars – then shows some field tests with steel TJM bars striking a 45 kilograms (99 pounds) dummy kangaroo at 80 kilometres per hour (50mph):
The next video shows the manufacture of an ARB steel bar:
An ARB Bull Bar Is Born | ARB 4x4 Accessories - https://www.youtube.com/watch?v=gjGweeNJClQ
Manufacture of an independent aluminium bullbar is shown here:
ECB Building the World's Best Alloy Bullbars - 1080p - https://www.youtube.com/watch?v=YwuFlFO2Ja0
Toyota explains how it does aluminium bars nowadays -- more impressive than my impressions way back in 2002 – shows testing with a 74 kilograms (160 pounds) test dummy kangaroo but does not mention impact speed:
HiLux: The Making of Unbreakable – Bull Bars - https://www.youtube.com/watch?v=YnSZGoRm2Kg
The point of this post really is to highlight starting with a clear idea of the purpose of the bullbar, then deciding on the type, material and most relevant design.
There is nothing wrong with aluminium bars properly made with the right alloys and thick cross-sections and used in the right circumstances, for example, where it is unnecessary to consider very heavy animal strikes.
It is worthwhile to understand the design and construction of any bar and whether and how it meets the owner's purpose.
Suggest be wary of an aluminium bar stated to be more that 30% lighter than the steel equivalent.
Some of the discussion at this link may be of interest.
Bullbar Buyers’ Guide - https://www.whichcar.com.au/gear/vehicle-protection/bullbar-buyers-guide
Same here Flint. Down here in the ArkLaTex we have some big animals that get into the road.
This is the exact reason I'm looking for a front bumper with full bar. Unfortunately, right now, it seems due to stock limitations, choices are kind of limited. The Ironman 4x4 front bumper looks to be a stellar deal at $1,000-ish (free shipping and 25% off Labor Day sale) and in stock, and it does what I want it to do, but I prefer the way the higher clearance bumpers look. Besides wishful thinking that the Kavik bumper becomes available again, I'm stuck either waiting until the end of the year for other options (Dissent on an order, TJM T13 per BumperSuperstore) or trying to find a TJM T17 and having a local fabricator weld on some hoops.
On that note, does anyone happen to know if the TJM T17 sits tighter to the front grill/headlights than the full bar TJM T13?
Tell me about it. 👍
We are overrun with Feral Hogs here.
See them dead on the side of the road quite often. They tend to 'go under' larger vehicles (Trucks, SUVS, Semi's) whereas Deer take out the grill and front of the vehicle. Sometimes come the hood into the windshield of lower vehicles.
I have a ranch that we live on and its a constant battle to keep them (hogs) beat back. We have to watch carefully when navigating the Rural Roads here.
