Once you solve the current problem, install a fuse at the battery for that new panel. You should install a fuse at the source not the load.
Tony
Tony
Sounds like you've got yourself a bad diode in the alternator... and something else going along with it!!
Oh - I just re-read that. You are only un-plugging the alternator? Try disconnecting the output wire from the alternator and see if it goes to zero.
or do all your wires disconnect through the plug (mine has a plug for the regulator, and a separate wire for the output)
Wiggle something when you took it apart? Maybe something dirty was lightly contacting a + connection somewhere and draining it... Something somewhere has moved.
Get your DVM back out, and unplug the alt. Meter between each pin (on the alt side of the plug) and ground. One of them will give you whacky resistance. FSM should list what the resistance should be (I would think?) Maybe someone else here can chime in, as my alternator is completely different (3B)
Good tip. I'll check that in the morning. Either way..I went ahead and got a new duralast from autozone. I figure the original alt (which I am almost positive I have) could use a rebuild after 270k miles. I order the parts from Cdan and keep it as a spare.
