New ‘85 FJ60 owner here. Tons of issues but currently can’t turn over engine. Battery is new. Was starting fine then suddenly not. Can’t determine where the drain is. Any obvious ideas?
Not sure if I’ve found culprit but little bit of research tells me if I don’t completely remove key that it may drain battery. Will do so going forward. Thank you John Staton for feedback.New ‘85 FJ60 owner here. Tons of issues but currently can’t turn over engine. Battery is new. Was starting fine then suddenly not. Can’t determine where the drain is. Any obvious ideas?
