See picture to see what cluster lights come on with ignition for lamp test. Why is the center locking differential light not included. Picture shown is a 2003.
Most likely the bulb is burned out.
Steve
The CDL bulb isn't in the lamp self test on start loop, but the VSC OFF lamp is, and as the CDL also turns VSC off maybe Mr T thought that was enough advisory info for the average consumer?
Sent from my iPhone using IH8MUD
There's several lights that don't light up in the ignition sequence, no biggie.
If you can hear the actuator on the center diff and feel it binding in a turn, and it locks and unlocks, but you have no light, the bulb is the likely next culprit. My OD bulb is out, makes me crazy when I get in after my wife has been driving it for weeks and I find the OD off. Worse gas mileage, yes please!
Trunk Monkey: Unfortunately my problem is looking more complex. I DO hear the actuator click but LCD does NOT engage. Codes say I have an open circuit so right now I'm following the FSM flowchart. Incidentally, in test #1 the bulb was good, but does not light with click of actuator, while both VSC lights are always on (I think you read my thread on this). While I'm chatting can you (or someone) tell me where the actual actuator is, and is there a physical linkage to transfer case?
Thanks
Yeah, go find a gravel patch and try it while slowly creeping forward.I've only tried to engage while stationary. Shall Itry on the move?...
You have to move to get it engaged. I think it may even be addressed in the owners manual.
Sorry you didn't get value from the other threads you started on this topic but I think you need to follow though a little better with your understanding of the system your trying to diagnose and follow a systematic approach to finding the solution.
All of this assumes you actually have a problem when following the operating instructions.
EDIT: Here are his original posts and efforts which should be good background for anyone trying to help out:
https://forum.ih8mud.com/100-series-cruisers/783130-code-47-repair.html
