FrazzledHunter
Thought so! THANKS!Bout 5 minute.
Thought so! THANKS!
I've read about the Carista product and I'd like to learn to do it myself. After reading this and other threads on here I'm honestly to point where I won't pay anyone else one red cent to program these.I did this a few years ago using an app on my iPhone and OBD dongle with OEM TPMS sensors and it took a few mins.
Great perspective.After reading this and other threads on here I'm honestly to point where I won't pay anyone else one red cent to program these.
Any other links on how to proceed with programming? I have tech stream already. If there is something more quicker and less complex I'm all in for it. Thanks
That is what I did, mine is a 2013 and stock with no issues. When I added a 2nd set Discount Tire took care of the programing and like I mention aside from a couple of time the TPMS light came on I have had zero issue. They charged me 1/2 price for the sensors (I paid around $20 or 25 each) when I bought a set of winter tires so I feel like I got a pretty god deal.I was just planning on using the TPMS in my stock wheels when I swap to 18” BBS wheels. My thinking is that there won’t be any programming required to use the ones that are already programmed for my truck.
Or should I swap them out if mine are pretty old at this point?
Are your TPMS original or have they been replaced? Original would be getting pretty long in the tooth by this point. I don't think I'd put those into new wheels and tires that shouldn't need to be opened for a few years.. but someone on here wrote up how to break a bead to replace a sensor using the factory bottle jack under the rear frame so they are salvageable if necessary. And programming really isn't hard.. carista makes it very simple, or using techstream.. I programmed new PI sensors today and even with booting up the computer the whole process took five minutes.I was just planning on using the TPMS in my stock wheels when I swap to 18” BBS wheels. My thinking is that there won’t be any programming required to use the ones that are already programmed for my truck.
I've had sensors become intermittent and it's annoying so I replaced mine on my 2018 at 4 1/2 years old when I got new tires. I used OEM and paid through the nose for the sensors & programming, $130x5 IIRC.I was just planning on using the TPMS in my stock wheels when I swap to 18” BBS wheels. My thinking is that there won’t be any programming required to use the ones that are already programmed for my truck.
What kind of sensors? The factory ones need to see pressure to turn on, then have pressure dropped during learning.. then increase it again to actually drive away. I banged my head against a wall for a while trying to figure out why I couldn’t get them to display then read the tags that actually came on them.. no more issues.Regarding new TPMS sensors and the re-learning process, once new sensors are registered with any TPMS tool, how long do these realistically take to pair with a 200-series LC?
Have had new wheels with new sensors paired but the PSI never shows up after hitting the re-learn switch, just the dashes - - -. Granted I don’t have far to drive, so I’m wondering if that’s the problem.
They were whatever DT installed when mounting new wheels/tires. Tbh, I’m not even sure they’re broadcasting the right frequency. That might be where I need to start.What kind of sensors? The factory ones need to see pressure to turn on, then have pressure dropped during learning.. then increase it again to actually drive away. I banged my head against a wall for a while trying to figure out why I couldn’t get them to display then read the tags that actually came on them.. no more issues.
I got new sensors recently and they worked fine. I rotated the tires and pushed the button to re-learn the locations and that worked fine. I later pushed the button again to set a new pressure range for warning since I was leaving on a long trip towing so running higher PSI but I only drove a mile or two after pushing the button. I didn't get the numbers back until I ran the techstream utility.They paired the sensors and I hit the Tpms button, the light blinked 3 times, and then I drove away. I thought better of it, parked in a lot around the corner, turned off and on again, repeated the procedure and sat for a bit. Never anything more than the 3 dashes.
