If you're going with a lift, stick to 33s. The negatives of a 33 over a 32 are nearly zero. Hell, even stock ride height with 33s looks best. Throw in the lift and you gotta do 33s.
Thanks for all the reply’s! The feedback has been extremely helpful. @agingfleet. Thanks for the comparison pictures. Are either of those trucks lifted?
I went 275/70r18 ridge grapplers. 1.25" spidertrax spacers on stock 18' wheels. 2.5" OME /heavy lift. Great stance I think. But I have ARB front and Slee rear bumpers so lots of extra weight. you should be good with a 1.5" lift with no extra weight on 275/70r18s. I added the spacers because with the extra height on the 33s the wheels looked sucked in. If you went with wider 33s you could probably skip the spacers but then you might get rubbing at full extension.33. I would say keep an on the width if you are wheeling and not running spacers. 275/70 r 18 is great common size with lots of choices.
it's off by about 4 mph at 55 mph on 33s. Yellow box will correct that. The NAV uses satellite. But you can adjust the tire size in the NAV so it will track more accurately based on wheel revolutions when you lose satellite.Does this throw off the factory navagation system? Is there any way to correct the speedometer?
Thanks
Did Costco install them, I read they wouldn't install non stock tire sizes285/65/18 KO2s from Costco. Had em for 6 months. Love em. I run 1.5in tough dog lift.
I wonder what affects MPG More? .4'' taller or wider?
Yes, they installed mine. The tech advised he wasnt sure they would fit. I assured him they would and they installed no problems.Did Costco install them, I read they wouldn't install non stock tire sizes
