Which size 32" or 33" ? help
Does this throw off the factory navagation system? Is there any way to correct the speedometer?
Thanks
I don't see how it would throw off navigation. I don't have that on my 98 though. Yellowbox is the only way I know to calibrate the speedometer/odometer correctly. I never did that and instead run an app on my iPad Mini which gives GPS speed. My iPad is mounted via a RAM mount on my dash.
Your probably right. Might throw off the miles to empty in the trip computer.
Does anyone have pictures of 100 series with 32” tires?
I have 32" tires on my 100. You can see them in my gallery. I wish I went 33's. If I knew KO2's ran small, I would have got 33's. The guy I talked to had 33" Toyo's and they rubbed (with the wheels I have).
285/65/18 (appx 32.5”tall ) ko2’s. Probably about 50% tread left. AHC normal height in the snow pic. AHC high in the other.
1920204
1920205
I think your truck looks good. What size rims?
Are you running Rock Warriors being that you have a 17x8? Soon i'll be picking some up and i'm trying to figure out what size I can run with no rubbing or having to use a heat gun to the wheel well... I have a stock 06 LC and will be using hubcentrics up front, want to put on KO2's but thought 285/75r17 might rub? Would I be safer with 285/70r17 BFG's? Any input is greatly appreciated.
I'm running FN Wheels Five Star wheels. My 275/70/17 KO2's don't rub at all. I went too conservative, I should have went 285/70 KO2's. In that size you also have the option of different plies.
Cool! Thanks for the info, 285/70 KO2's it is. It's my DD and it doesn't see many trails, so I was leaning towards C loads.
Depending on what wheel you go with, you might rub. A spacer and/or pinch weld mod might be needed.
Really leaning towards the 275/70r18 Just hoping they dont look goofy small. Trying to find more pictures in that size for analysis.
They definitely won’t look goofy small. They look good. It’s not until you see someone with slightly wider tires that you have tire envy. But different strokes for different folks
Wait, you were looking at 32s and now you're afraid 33s are too small? They look good. 34s and 35s look great IMHO, but typically require additional mods and have other complications.
Thanks for the replies. I mistyped , I meant going with 32”. I know the 33 look awesome, just concerned about the real world impact of going to the 33” size. Maybe I’m overthinking it a bit
For comparison I pulled a 32”ko2 off my f150 and put it next to the lx on Ahc high mode. I think it looks sufficiently awesome without being too pretentious. What do you all think?
1921801
1921802
