Hi Rudi, thanks for that, so "OI & D" gives me power to the VSV when the ignition is turn to ON & START :-
So when the ignition is ON, power is on the "Left Relay" which in turn moves the "Middle Relay" into "D" (RUN) position, when the ignition key is turned to START the "Left Relay" changes to the OI position (START overject), when the key is released back to ON the "Left Relay" sends power back to the "Middle Relay" which in turn moves to the "D" position.
What I don't understand is when the key is in "ACC" (OFF) power is still always on "+B" from the FL of the battery, can you explain to me what's cutting the 12 volt power supply off internally in relationship to the "Right Relay" where "B" & "M" are concerned.?
