Hi Rudi, started the 12ht this afternoon, all good. The power to the VSV works perfectly, the change from OI to D is not noticeable at all, engine shuts down immediately on ignition turn off.
The conversion to the 12HT engine fuel relay using the HJ47 wiring loom works with the incorporated low oil pressure shut down of the 2H oil pressure switch being installed on the 12HT engine.
Heat screen relay comes on with starter motor start, all seems to work ok, cold idle up works as does the power steering idle up, thanks for all your help with this.
