Some OBD 2 readers are able to also read proprietary data that are not part of the standard protocol. Looking for the most compatible reader for 200 series. Thank you!
I use scan gauge 3 which is excellent!Some OBD 2 readers are able to also read proprietary data that are not part of the standard protocol. Looking for the most compatible reader for 200 series. Thank you!
is this the right part?suspecting my OBD fuse may be broken. its 7.5 amp at location number 27 on driver side (under steering wheel). Does anyone know the fuse model number or size if I have to buy a replacement. Also any good fuse removal tools you know of which can get this small fuse?
Nice, glad to help. And the Evo is a nice device.. I did a full scan of my truck on the road today and it was noticeably quicker than the original.Thanks @bloc , finally figured out that its a blown out fuse for OBD which is not powering my carista.
Now I remember, a year ago I was using another obd2 bluetooth live data sensor with obdfusion app. I thought the adapter stopped working after 6 months and tossed it. Now it makes sense that the fuse was blown.
Was able to use carista evo to update the tpms sensor.
I know you can use the original Carista OBD scanner with OBDFusion. Assume the same goes for the Carista EVO?Nice, glad to help. And the Evo is a nice device.. I did a full scan of my truck on the road today and it was noticeably quicker than the original.
Works fine for dashboard and diagnostics on my 2013.I know you can use the original Carista OBD scanner with OBDFusion. Assume the same goes for the Carista EVO?
