I think Marlin has the detent balls.
Thank you Juggernaut.
I reversed the castle nut myself. I have since gotten the knuckles all the way apart and removed the steering arms with a pickle fork, tearing the heck out of my tre boots and revealing the internal rust. Should I be getting new 555 tre's or is there a better alternative out there?
I have not seen bearing races being replaced in the write ups I've read. One of my races was shot, looking at the bearing that was in it it's no wonder (pic #1 post #2). That was a Chinese bearing and I had a shop press in the new race, which is a Koyo. However that still leaves me with three old bearing races in the hubs.
My FSM shows setting preload on the trunion bearings (right term?) but I have not seen others do this in their writeups either, unless I'm missing something.
Three studs came out of my knuckles as I removed the trunion bearing posts (term?)
[EDIT]I bought some '95 4runner calipers and pads and will be installing them instead of rebuilt LC calipers. I had the rotors ground; they are marginal thickness but waaaaay better than they were. However since they've already been machined I can't press in new races, and since they're so thin if I need to it will mean buying new rotors and attaching them to my old hubs, which I am trying to avoid because the $$$ is piling up fast.
Questions:
- Anyone have feedback on TRE's?
- Are my old chinese bearing races OK with my new Koyo bearings? The sizes match up, best I can tell.
- Do I need to worry about preload or will replacing the shims as I found them take care of this? How do I set preload? [EDIT: figured this out]
- Can I just put a second nut on the knockle studs and drive 'em back in there? Judge how deep to drive 'em based on the studs that didn't come out?
- How do I remove the axle seals without the SST?
I am in the middle of this again after a rainy weekend with the family and would appreciate any help offered. Thanks for reading.![]()
I found out Marlin has the hub ball and spring but bummer, it's $3.99 which is not that bad but the cheap slow shipping is $8.75, and the get it here in a couple of days shipping is $15 or something. This is how I learn to pay attention to what I'm doing with parts I guess.
Thanks for the tip about the bearings. I'm planning on using the old bearing to tap in the new race, so it goes socket-->old bearing-->new race, is this right?
I found a pdf about a knuckle-centering tool online, here it is, not for the first time I'm sure. It also helped me to understand how to use it since I never have before.
As far as the knuckle "moving freely" that's a broad statement. Pull on the steering arm and pretend your pulling up Xamount of # like I said. I dotn remember the preload specs 8-12#? but I would shoot for 10# and if you are running this is important! either bigger tires 33s or up OR! spacers or less BS wheels like 2.5 BS then I would go 14-15# use your finger pick up X# then pull on the arm it should feel the same.
[EDIT] Yeah, got another hand and it wasn't so hard anymore. Nothing to see here, move along folks...
looks like you are almost done?
The diff is glued to the housing with years of axle smegma. If your positive all the nuts are off ... put a jack under the nose of the diff housing and jack it off![]()
