“If I have seen further, it is by standing on the shoulders of giants.” – Isaac Newton, 1676
I’m not much of a wrench—though I know a little more now than when I started this thread—so I thought it would be a good idea to put all the materials I needed, and online tech resources I relied on, in one post so others could see what I found helpful. I used all of those tools, and almost all of these links (plus some others that I can’t recall). Needless to say, the fact that so many other mudders were willing to help out was absolutely invaluable. Thank you!
I also leaned VERY heavily on my outstanding LC-specialist mechanics, Willamette Boulevard Service Center here in Portland OR, though looking back I see I didn’t mention it. Josh and Larry are absolutely the salt of the earth. Tony at Land Cruisers Northwest also bailed me out a couple of times, much appreciation to both excellent shops.
FSM: I have a body & chassis full service manual that I downloaded a while ago, and had my wonderful wife print and bind for me. No idea where I found the document though. But searching for it got me to the below pages. There is a TON of good tech available for download at these links:
https://forum.ih8mud.com/70-series-tech/185322-online-manuals.html
Toyota Workshop & Repair Manuals - Page: 1
Toyota Factory Service Manuals (FSM) - all years - YotaTech Forums
For this job I referred to these webpages.
Knuckle rebuild tutorial videos (from mud user lshobie):
Land Cruiser rear hub/axle service, bearings, axle, seals, gasket etc - YouTube
Toyota Land Cruiser front Knuckle rebuild tutorial #2 installation - YouTube
And many mud threads as well. Search was my friend.
Hub rebuild thread and video (video again from lshobie):
https://forum.ih8mud.com/79-95-toyo...ng-aisin-locking-hub-locking-hub-rebuild.html
Aisin Manual hub (free wheeling hub) rebuild Toyota Land Cruiser- YouTube
4runner Brakes threads:
https://forum.ih8mud.com/60-series-wagons/84730-4runner-brake-install-pics.html
https://forum.ih8mud.com/60-series-...-rotors-backing-plate-eliminator-install.html
I ran into some trouble with my brake master cylinder, seems like it’s not too uncommon when replacing calipers:
https://forum.ih8mud.com/60-series-wagons/603225-rth-my-brake-mc-makes-me-want-kill-something.html
PART 1 - Brake pedal goes to floor
Other helpful links:
IH8MUD 60 series FAQs:
https://forum.ih8mud.com/60-series-wagons/13183-fj60-fj62-faq-start-here-come-back-often.html
Electronic Parts Catalog (found this after my repair was 99% done, could make ordering parts much easier):
https://forum.ih8mud.com/sc-upstate-cruisers/191314-great-cruiser-parts-link-thread.html
ToyoDIY.com
All of lshobie's tutorial video links in one post:
https://forum.ih8mud.com/60-series-...-rebuild-video-tutorial-uploaded-youtube.html
This is a materials list of what I used on this job, your mileage may vary. I tried not to leave anything out, suggestions for overlooked items welcomed:
TOOLS
o Auto tools: torque wrench, sockets, breaker bar, wrenches, jack stands, etc.
o BFH and brass drifts, I used one small one and one large one. Use safety glasses.
o Snap ring pliers, very important
o Dremel with cutoff wheels, grinder wheel, and wire wheel
o hand wire brushes for parts cleaning
o torch (for stuck stuff)
o 54mm socket
o fish scale
o tie rod separator (screw type, NOT pickle fork). One trick for separating the TRE, put tension on the stud with the separator and then smack the steering arm about half-way down, the vibrations will loosen the stud. Or so I’ve read, but didn’t try…
PARTS
o new TRE boots (I used a pickle fork
o complete front axle rebuild kit from Cruiser Outfitters, incl. Marlin axle seals instead of OEM (though I didn’t actually get these)
o also get a spare hub seal (goes over inner wheel bearing, they're hard to get in straight—or in the right order, ahem—and easy to screw up)
o Reman ’95 V6 4runner calipers, plus brake pads
o Reman fj60 brake master cylinder
o I also needed to purchase (cheap) a used short side axle and a couple of new birfield inner snap rings from Willamette Blvd. I got a free extra détente ball and spring for the hub face, plus the spare inner hub seal, from LCNW. I also bought some little stuff from the dealer. None of that was cheap though.
SUPPLIES/CONSUMABLES
o penetrating lubricant, apply early and often
o wheel bearing grease
o box of rubber/nitrile gloves, plus 2 pair heavy rubber gloves
o brake cleaner
o brake fluid
o tub of mineral spirits/gasoline for parts cleaning
o cotter pins for TRE (I reused my old ones)
o primer and paint if you repaint your axle/knuckles (though I didn’t, you might as well, they'll be as clean as they’ll ever get now)
o cheapo toothbrushes
o MANY rolls of paper towels. Like five or six. I used most of two boxes.
o I also put the whole shebang on top of a ¼” plywood sheet to keep the driveway clean.
o Gasket, and gear oil, if you open your diff like I did.
Many thanks again to all the folks willing to help. Let me know if you're in the Portland OR area and we can compare rides, and after that I'll show you why they call this place 'beervana.'
