Final knuckle rebuild video tutorial uploaded to youtube.
Hi Guys,
I've made the last hub/knuckle/brake etc rebuild video, go here to check it out:
Toyota Land Cruiser front Knuckle rebuild tutorial - YouTube
And these are some of the other videos in my series:
Video #1 Toyota front knuckle, hub, and brake service overhaul Video #1 Removal.
Toyota front knuckle, hub, and brake service overhaul Video #1 Removal. - YouTube
Video #2 Aisin Manual hub (free wheeling hub) rebuild Toyota Land Cruiser
Aisin Manual hub (free wheeling hub) rebuild Toyota Land Cruiser - YouTube
Video #3Land Cruiser rear brake service, shoes, drum, emergency brake adjustment
Land Cruiser rear brake service, shoes, drum, emergency brake adjustment - YouTube
Video #4 Land Cruiser rear hub/axle service, bearings, axle, seals, gasket etc
Land Cruiser rear hub/axle service, bearings, axle, seals, gasket etc - YouTube
Video #5 Slee Castor Correction Bushing install, Land Cruiser Tutorials.
Slee Castor Correction Bushing install, Land Cruiser Tutorials. - YouTube
Video #6 Land cruiser 1HZ 1HDT 1PZ Valve shim adjustment tutorial
Land cruiser 1HZ 1HDT 1PZ Valve shim adjustment tutorial - YouTube
Video #7 Warn 8274 winch rebuild series #1, disassembly of winch
Warn 8274 winch rebuild series #1, disassembly of winch - YouTube
Video #8 Warn 8274 Rebuild video # 2 Re-assembly of winch
Warn 8274 Rebuild video # 2 Re-assembly of winch - YouTube
Thank you!
Great videos, wishing having them before had completed my knuckle rebuild...
Someone should put them sticky or in the FAQ!
Man you are awesome! Can't tell you that enough. You've totally changed my view on some of the jobs that have been scaring the bejesus out of me for the last year. Good work man.
Man.. simply amazing VIDs... Im sad that I didnt have any of these before I did the work, but these should help lots of others.. Thanks a ton.
Thanks guys, better late than never though! More vids coming - please subscribe!
Great Louis .. thanks !
Which it's your fav grease for knuckle .?
You miss the knucle seal secuence using the marlin wipe seal .. that would be good to see as reference.
You are amazing. Really helpful. Thankyou!
