Which Alternator - April 2020 Edition
USA
I have open the multiple threads on alternators for the 100-series.
Although I've read them, I still have questions.
I'm about to order a replacement via RockAuto.com
I wanted to do the "Sequoia alternator upgrade", because other than electric-chair candidates, who doesn't want more amps!?
Yet I am unsure which year the Sequoia alternator to order.
2009 Sequoia has two engines, 4.7 and 5.7
I assume the 4.7 is the same engine as my 2000 LandCruiser (actually an LX470, yet same s*** different badge).
I checked the 5.7 engine alternators, and they come more beefy (up to 180 amps), yet the plug is on a completely different place (off to the side).
So if I wanted the highest amp alternator that will fit a 2000 LandCruiser, which one should I order?
Thank you!
I think the 1st gen Tundra comes in a 150 amp variety? You didn't say your model, i think the 100 series came with alternators ranging from 100 to 130, if I'm not mistaken...
Go to the denso website > Find my part > enter any Sequoia with the 4.7L engine > Select the 150A model > buy from reputable local shop.
Looks like the second plug.
So dumb question, but what happens to the extra wire when going from the 3 pin rectangular style to the 4 pin square?
Would probably need to compare the electrical diagrams from the sequoia and the LX
snip short, fold over, and heat shrink over the nub. it goes to nothing
the only worry is existing age/condition of the main wire going back to the battery. it should either be in good condition or upgraded to a thicker gauge
that 220A seems interesting but most around here only stick to OEM when possible and i want to know how they are pumping out an additional 120A out of the same casing as the stock alternator. they seem like a legit independent alternator shop but i have a lot of questions. the 220A would almost def require some degree of rewire for the mains. but its yet another possible option.
edit: that pulley looks smaller so maybe that is part of it.....
I got their 250. Direct bolt on. Solid unit. Has been taking the beating my stereo is giving it for two and a half years. About 3k watts
Yeah no idea how it's done. Regarding the pulley, though, it looks about the same to me.
210-0565
How much wiring did you upgrade?
2/0 flex welding wire:
Alt to battery
Engine block to chassis
Battery negative to chassis
Battery negative to engine ground.
alt is direct bolt on and plug and Play
did the the Hkb voltage booster too
Man I got a 175 from Mechman and it was plug and play. US made and can send back to be rebuilt but it has been awesome and solved all my charging problems on dual batteries and all my power drainage...
It was been under water alot and no issues....
Great people to deal with.
Alt to battery
HIGHLY HIGHLY recommend this. Even if you just go stock alternator the wiring is anywhere from 22 to 13 years old..
