FCT-017 or FCT-004? Could some please help with this ? And point me in the right direction here for tips, tricks, go-bys? Thanks very much
Thanks!!!Not a parts expert, but AFAIK:
FCT004 is the standard fan clutch for a 93-97 FZJ80 with the 1FZFE engine
FCT017 is for the 91-92 FJ80 with the 3FE engine
This one. It's legendary.
HD Fan Clutches
HD fan clutches tuned to flow more more air throughout the operating range to better cool the engine and lower the temperature of the AC during idling times. There are 3 variants: Modified Blue hub for NA engines Modified 1HD Orange up for Diesel engines. Modified SC Orange hub for Supercharged...landtankproducts.com
Well, as you know, this is THE blue fan clutch mod of landtank fame. And as you also know, if it's good enough for nlxtacy and wits' end, that's 5 stars right there.Why is it legendary?
So it’s worth the $$$$This one. It's legendary.
HD Fan Clutches
FCT-049 is for the 3FENot a parts expert, but AFAIK:
Only if you don't want to do it yourself...So it’s worth the $$$$
Ahhhh I see they go to the trouble of properly lubing it etc…thanksOnly if you don't want to do it yourself...
I ordered a new aisin and attempted to open it up only to round a screw head. Redline landcruisers has a modified as well, similar price. I'm not familiar with either company. Can someone provide some insight into which company I should go with?This one. It's legendary.
HD Fan Clutches
You might know this but the oil is not lubricate primarily. It provides resistance within the fan clutch and allows the fan clutch to pull air. No oil, no fan moving air.Ahhhh I see they go to the trouble of properly lubing it etc…thanks
Makes sense thanksYou might know this but the oil is not lubricate primarily. It provides resistance within the fan clutch and allows the fan clutch to pull air. No oil, no fan moving air.
