Where to get FJ60 spring bushings
yep.
x2 - what he said.
no one asked if they were stock bushings.
If the springs are stock they are 70 mm wide.
Aftermarket range from 2.5" to 70 mm ( 2.755" ) and if are narrow require a special bushing
Stock shackle pins are 18 mm. Some aftermarket are 5/8" or 3/4' pins Make sure you have that info.
Many complaints with vendors are a result of customers not ordering the correct part.
no one will complain about Kurt, ... unless you don't want good friendly old school service and don't wanna talk to anybody/let me buy it online with no certainty of what I am really getting... you get the point.
then again, with that said they ante tre's you want cheap crap you can go elsewhere... not recommended.
I got mine from ebay, rubber bushes all round, fitted them myself when I put in the OME springs.
I ran rubber spring bushings with my OME suspension for a while. They did not last very long. Keep an eye on your springs.
I thought rubber would give a softer ride and more give when twisting / flexing.
Unless there is a good synthetic option that has enough give for twisting, but lasts long enough, and doesnt crack up.
It theoretically will give a softer ride and more give when flexing. That is also what tears it up...
Synthetic lasts longer..
Yea ok, makes sense I guess. I'll just keep an eye on them, I have it on the hoist regularly enough anyways. Just put all new rubber bushes in, not about the swap them out at the moment.
mine were about a year before they died.
In a stock cruiser they work fine. Start modifying things and things go south.
Here is a dumb question, and I didn't find it on the website.
How many of these kits do you need per truck? One kit per spring, or one kit per axle?
you will need 24 individual bushings, 6 per leaf spring. depending on how old and worn the spring pins and shackles are, you may want to consider changing them also
