I have wheel dilemma with my 91'and 96' Cruisers. I am a long time lurker but haven't posted much. I would like some opinions. No I an not looking for which, tire, wheel. oil is the best... So here is the background:
I bought the 91' TLC several years ago. It had the 15" factory wheels on it with worn out tires. I found a set of 5 factory 17" FJ wheels with new oem tires that I put on. I sold the 15" wheels. The 17" FJ wheels looked great on the 91' and I could use the rear center caps.
So recently after looking for some time. I found a locked 96' for a good price. I wanted the air bags, ABS and 4 wheel disc brakes when its used as the kid hauler. The 96' had the factory 16" wheels with worn out tires.
So I swapped the wheels and put the 96' factory wheels on the 91' and the FJ 17" wheels on the 96'. So I took the 96' with FJ wheels in and had stock size Geolanders put on. Are you following me?
The 96' has running boards which make the different offset from the FJ wheels look worse. Also the caps don't fit. I know I can get spacers for the FJ wheels to remedy the offset issue. But not sure if I want to go that route. I am going to sell the 91' In the future I plan to do a 2" lift with 33" tires on the 96'. The 96' is mainly used as a back country camping/kid hauler
So finally here are the questions given all the variables.
Should I swap the wheels back and put 33" tires on the 96' factory wheels and the 17" wheels on the 91'? I just bought the Geolander tires that are on the FJ wheels which would go out with 91'. I would then have to buy new tires for the original 96' wheels.
Is everyone properly confused?
In retrospect I should have just bought new 33" for the 96" and call it good. I know I am over thinking this but I plan to keep the 96' for along time. So I want to do it right choice before selling the 91'.
I
I
