zuluzeugma
Here's an update. My brother (he's a jeep guy.. uggh) and I went by and took a harder look and longer test drive. It starts right up with no major engine problems... the only thing is a wobble in the power steering pully. There's a repair order in the truck for a rear main seal replacement and clutch replacement... looks to have been done in May of this year ($1000 in repairs). She runs awesome, but the front end knuckles might pose a problem... the steering seems to catch. It cycles between being easy to steer and hard to steer... I'm not sure if it's a power steering or knuckle problem. She didn't want to get out of 4hi but we eventually got her back into 2 ... I think she was wanting to do some wheeling. As far as the diff gearing, it ran about 2000 rpm @ 55mph in 5th with enough power to pull it up a few decent hills in nwa.
I'll try to get the compression checked and get a cruiser guy to check it out asap.
Thanks for all your help.
You have stock gears then. Sounds like it was well taken care of.
Engine RPM: 2000
Tranny First Gear: 3.9
Tranny Final Drive: 0.83
Differential Ratio: 3.73
T-Case low Ratio: 1
Second T-Case Ratio: (Enter 1 for none) 1
Tire diameter (in): 33
Engine Angular Velocity(rad/s): 209.4395102
Hwy Speed (ft/s): 77.20625377
Hwy Speed (MPH): 52.64062757
Overall Ratio: 68.3709
Crawl speed at idle (ft/s): 1.684806411
Crawl speed at idle (ft/m): 101.0883846
Crawl speed at idle (MPH): 1.148731644
