Pulled the plugs as PM and decided to borescope the cylinders out of curiosity. Found this in one of the cylinders (driver side closest to firewall). What is this? Is it coolant (HG failure?). Really hope not. Attaching a few images. Thanks.
Looks like a bit of oil got baked in. This can happen if your spark plug has backed out a bit and you have leaking valve cover gasket tubes.
Similarly it could be caused by a longer term rich condition on that cylinder; usually a coil pack or bad plug.
Did the plug have any signs of oil on it? What does the spark plug look like? Are the valve cover gaskets and spark plug tube gaskets new?
The DS closest to firewall spark plug is in my experience the plug that has started backing out every time before the others. So something to look at.
I had thought that to be the case as well. Just curious what that residue is then - it almost looks pinkish like dried coolant but then again its a pretty cheap borescope. The other cylinders didn't appear to have this residue when I scoped them, although I didn't bother to crank the engine for the cylinders where the piston was toward the top of the hole.If you had coolant loss, the piston will be steamed cleaned and looks shiny.
The #7 piston top looks a bit to clean. Spark plug from cylinder #7, also a bit to clean. But really the pictures aren't great/clear. So making any call difficult. Your #7 is cleaner (or appears so) than one I pictured below. If all your piston top the same, as your #7. Then likely HWY and or some fuel and or intake de-carbonizing done. So your good. But if only #7 piston top clean. I'd do more testing! Test that can be done now, while cold and plugs out. Pressurize coolant system to about 15 to 17 PSI. Then look into #7 cylinder again, for any coolant leakage at head gasket. Also noted any coolant loss, since you've owned and was system low when you bought. Clues!
Looks like the spark plug of that cylinder has some residue in the threads. Also the plug hole threads look a bit dirty/carbonized, like the plug has been loose, but not loose enough to damage the threads.Here are the 4 DS plugs in order. Plug on the left was closest to the front bumper, plug on the right was the closest to firewall.
Here's a shot of the threads from that cylinder's spark plug hole.
Valve cover gasket is original. Don't see any oil leaks externally.
