OK take it easy,who cares about legality. Damn,im glad i didnt ask about immigration laws......i'm not getting beadlocks!!
i warned you th at it would be a heated debate,
and i don think a ring is simply going to fall off????
ok anyway
meh
I am not a bead lock expert nor am I an legalities expert........
you are not allowed to alter rims in any way shape or form (law)......
if your rims were manufactured with and for beadlocks then there should be no legal restrictions on running them.
ill be back so you add weight to balance a tire and its illegal, or you add a chrome valve stem, or some sweet paint
...(ii) equal to or greater in strength and durability than the original parts provided by the original manufacturer.
[so the question becomes one of interpretation, did the legislature mean strength and durability to really mean likelyhood of failure, if so that would make beadlocks illegal. IMO at least the ring style beadlocks, especially those built at home, are more likely to have failures than OEM wheels...
My rig is fugly, nobody would mistake it for a Mall crawler. I think people actually avoid parking next to me at the mall....Is this just a fad for looks with a little bit of protection? Mall huggers in need of attention? I see the DIY weld-on locks,whats the advantage to this set-up? Is it worth the aggravation of worrying if one bolt is overtorqued? If it is, who makes the best DIY?
My rig is fugly,
And yes there are probably a lot of people that have them just for looks. But the same could be said of sliders, nose hoops, etc. Just because they are popular for the look doesn't mean that they don't have a real function.
Stauns are a good compromise if you do not want to deal with locks..
Recentered hummer rims are probably the most cost effective.
What is your available funds?
The really cheap locks are seriously weak.
You do realize that they sell Civilian hummers right?hummers are not dot approved and cannot be bought surplus . you can strip off all the parts and the body has to be ground up on site .years ago some escaped whole due to a loophole , thanks usmc , same goes for some other military trucks as well .if you cant buy a hummer from the military are hummer wheels dot aproved when the vehicle itself is not thanks and good luck
mines arould there. i think 35. There are alot. i dont like the 15 bolt bead locks. Seem like alot of force on each bolt. I have seen some bolt head break before. I seen many break from corr racing from wheel to wheel contact. Bead locks have save me MANY trips from getting out and taking the co2 out. But it really suck after they leak air and you have a rear lockerthat is why i have 33 bolts per wheel and i dont think a bolt head will just snap off on grade 5 bolts
If driver error is utilizing lower pressures in the tires for greater traction...
