He is probably going off the info reported here numerous times that a reverse switch for a 2000 5spd Tacoma is an appropriate and more affordable solution to the diff lock switch.
From jonheld———-
There are 3 switches on the transfer case.
Two 84222-12010
One 84222-60081
From Tools R Us——-
What switch are you attempting to access? Looking at the NCF info starting in post #45,
CDL Actuator Fun there are two switches relevant to the CDL. The 4 low position switch, senses the 4 low shift and turns on the CDL system, is on the rear of the transfer. The CDL indicator switch confirms CDL activation, turns on the dash light, off ABS and activates the axle lockers (if equipped).
If inop, both can be relatively inexpensively replaced. From your favorite parts store order a
reverse light switch for a 2000 Tacoma with a 5spd trans.
And Kevin’s thread about CDL functionality
Yes, it's grey and has two plugs. I believe it is C 2 on the electical diagram, when I jump it the CDL lights and ABS lights stay on. Some have had luck with pulling that switch and exercising it, pushing the ball on the end in multiple times. It's easy to test it when it's out, the contacts...
forum.ih8mud.com
