I just acquired an old downey aluminum sbc bellhousing adapter for an h42 and was looking for some information about what throwout bearing to use. I tried to reuse my old toyota bearing but it doesnt seem quite right. Thanks in advance!
generally you match the throwout assembly to the clutch. The early three speeds had a three finger clutch with a flat faced bearing. The H-42 used a diaphragm clutchI just acquired an old downey aluminum sbc bellhousing adapter for an h42 and was looking for some information about what throwout bearing to use. I tried to reuse my old toyota bearing but it doesnt seem quite right. Thanks in advance!
Do you know which clutch fork and slave you worked around? There are two distinct fork/slave setups for the 60 series and then the adjustable slave/fork on the 40 series.When we machined stock new cast iron Chevy bellhousings into 4 speed adapters, we also included a new "re-machined" front bearing retainer for the transmission, it was machined to clear part of the Chevy bellhousing, and to use the smaller I.D. Chevy throw out bearing. Once we manufactured our own 360 degree aluminum 4 speed adapter bellhousings, we designed them to use a stock Landcruiser throw out bearing on stock hub, stock shift fork, and stock shift fork pivot ball.
Gee Whiz information: It was a lot easier to buy 100 new Landcruiser bearing retainers than it was to buy 100 Chevy bellhousings, the bellhousings would drift in to Downey 5-10 at a time, and we didn't set up machinery until all had arrived over 1 to 2 month span.
It's usually the little things that make it work , at least work wellThanks everybody! So I goofed and didn't look at my old clutch on my 1f, I assumed they put in the new style diaphragm clutch when it was converted to a 4 speed... Nope they just reused the old three finger style clutch so that explains why the throw-out bearing wasn't right. Time to find a 4 speed hub and throwout bearing!
Thanks but I’ve got the clutch covered but I do have one more question about the bell housing.And if you need a new "Chevota Specific" clutch, talk to me
