I took the vehicle to that person to increase fuel. He did some adjustment and said that there is no room for further increase of fuel. He said that the pump plungers and nozzles need to be replaced with a new one. Sadly.
However, we did manage to increase a little bit. So what was the result?
a) Actuator pipe attached; No performance gain. I noticed a little black puff with full throttle, which was a sign that indeed fuel had been increased. 5-6PSI @ 3500rpm.
b) Actuator pipe removed (max PSI); Smoke vanished, PSI touched 20 @ 3500rpm 3rd gear.
HAHAHAHHAHAHA!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
What POWER! It is not like what it used to be but there is a visible improvement! I LOVE IT I LOVE IT!
The person who did all this adjustment said that this is not even 50% of the power of what a factory 13B-T has. He pointed to nozzles and plungers; they need to be replaced. He said that max injection volume is too low and plungers do not have the power to inject any more.
I asked him if I need to worry about EGTs and he said that this 13B-T is still under fueled. He did however said that I need to replace the wastegate actuator as it is not functioning properly (it opens up too soon). Hence, with the existing waste gate actuator, I will get higher EGTs due to lower boost.
I will explain the fuel adjustment points in my next post.
KOOTENAY KRUZER:
Good point. But where can I find a new OEM thermostat? I can get used OEM thermostat but again the problem would be how to recognize that it is for 13B-T?
